Just type out what youre buying so we don't have to click a link
I have after market billit intake with no boost bottle with an internal cross over
Pro design Billit timing plate
Pro design billit cool head with 21cc domes w/ head gasket
V force4 reeds
Extended swing arm +6"
+6" brake line and
Chain
Flywheel puller tool
Price im at right now is 1,364
Okay now let's be real.
What about a carrier?
Bearings for the carrier?
Bearings for the swing arm?
Caps and seals for swing arm?
Brake pads?
Shock linkage bearings?
Shock bearings?
You realize with a +6 on a probably junk rear shock the thing will handle like shit and you'll bottom out all the time.
You need to account for stuff breaking or unforeseen issues
Like the fact you will have almost zero traction. How are your tires?
You shouldn't run a new chain on old sprockets. But that's not a crazy issue.
You shouldn't have a budget and blow it and have no cushion.
You will find something you missed or now need.
  • Like 1
leave your stock intakes on and plug the holes with 3/8 IPS plugs, 2 hose clamps, and 1211... Crossover is not needed.
mod your stock timing plate
unless you are hell bent on different compression the stock head is fine. The "cool" part of cool head is virtually useless in a stock trim bike.
Buy a puller
Look on here for a COMPLETE used +4 arm.
OK, sure, buy the reeds and pancake
  • Like 1
In my experience, a stock rear shock thats in good working order will only ride somewhat nice up to a +4 swing arm. Anything over that really starts riding like shit
  • Like 1
