Yamaha_Banshee_Living
Everything posted by Yamaha_Banshee_Living
  1. Where would i get it than?
  2. Ok so what would the best ideal gas to run, i could go to a air port and get 110. Or is there something else o should run ?
  3. I ordered the cool head, domes and timing plate 2 days ago they should be here by the end of the week ill be doing alot of dune riding this coming season. Im not getting it ported till probably around december because im short on money right now but im getting my crank welded also
  4. I have pro design 18cc cool head domes timing plate and fully race ported what kind of fuel should i be running all i have around me that i can find is pump gas and than one gas station has 91 no ethanol gas and i was told i should run the 91 no ethanol any suggestions?
  5. Its stock right now. When winter is over it going to be ported and bored 30 over, im doing alot of work to it, firt time ever tearing into a banshee. I want to learn banshees and make it look bad a** the way there
  6. What shock would be best for a +6 swingarm with 160 lb rider not looking to spend over 500
  7. What rear shock should i purchase for a +6 swing arm around 450 bucks
  8. I have after market billit intake with no boost bottle with an internal cross over Pro design Billit timing plate Pro design billit cool head with 21cc domes w/ head gasket V force4 reeds Extended swing arm +6" +6" brake line and Chain Flywheel puller tool Price im at right now is 1,364
  9. Alright here is what i have in my cart right now. I only have 1450 to spend. Let me know if i should get rid of something or get something else!
  10. Ok thank you thats what i was thinking just wanted to make sure
  11. Yes they are the same length
  12. Okay thank you i didnt know that i could do that i havent been on here verry long but now i know thank you verry much !
  13. Whats the diffrence between having a intakes with boost bottle and intakes with a built in cross over
  14. I have basicly a stock bike at the moment. All of you probably know this by now. I got stock bore toomey t5 and k&n dual air filters But im ordering parts and mods for it tomorrow. Should i get bigger carbs and what size?!? Thanks
  15. Like one i have to screew in really far to get it to touch and the other not so much
  16. I have a 2004 banshee that i plan on putting alot of money into over time. But at the moment im playing with the idle screws and all that jazz but i loosen the idle screws all the way,so there not touching slides and then slowly screw them back in till they just start to touch the slide but one screw touches the slide before the other. Is this normal?
  17. Thank you all im going tk be adding druff in the shopping cart and see what i wnd up with
  18. I have 1400 to spend on mods and parts. For my banshee its stock bore with toomey t5s and dual k&n air filters What would you recomend ?
  19. Im going to be taking carbs off tomorrow checking reeds and for air leaks
  20. Yes i did they are both going up at the same time .... is there any thing else it could be ? It was lacking a little bit of power before i fixed my slide problem but now its worse...!?!?!?
  21. I figured id hop on the banshee to see how shes running. I was lacking power in every gear and it would bogg out of the powerban in 4th gear and 5th gear. I have just about 8 hours on it. With toomey t5s K&n dual airfilters Please help.
  22. Could this cause lack of power?
  23. So i was just checking over the shee and noticed one of my slides is lifting up before the other side. Is this a problem? Thanks
  24. In the future i plan on getting it ported i just have to find some where around me that does it reasonably priced. And what other mods and things u guys would recommend i do plan on getting new shocks.do you have Any brands to preffer?
  25. I was trying to look up picture on how a 4" would sit because i really like the way the 6" looks on my year banshee and i dont want to get something im not gunna like ya know im bassicly getting it for looks
