Thats what Shee said Posted August 8, 2016 Report Posted August 8, 2016 Can someone explain that the differences are between pv, Cubs, cheetahs, severals, and what ever other motors I am missing. I hear talk about thear motor often and would like to understand what they mean. Quote
Pasi S. Posted August 14, 2016 Report Posted August 14, 2016 CUB:Stock intake and stock head bolt pattern. PV/PowerValves are not an option. Cheetah: Mid-Top end power. Serval: Low-Mid range power. Wampus: (Cheetah/Serval power) Stock Cylinder appearance. Super CUB: Bigger than 68mm bore. Stock intake bolt pattern, but different head. DM, DMX, Scimitar, Cougar and Caracals are bigger and not for askholes. (joke) Quote
Thats what Shee said Posted August 14, 2016 Author Report Posted August 14, 2016 CUB:Stock intake and stock head bolt pattern. PV/PowerValves are not an option. Cheetah: Mid-Top end power. Serval: Low-Mid range power. Wampus: (Cheetah/Serval power) Stock Cylinder appearance. Super CUB: Bigger than 68mm bore. Stock intake bolt pattern, but different head. DM, DMX, Scimitar, Cougar and Caracals are bigger and not for askholes. (joke) I am new to everything and would like to learn more. What would be the best way to do this? Quote
ClaudeMachining Posted August 15, 2016 Report Posted August 15, 2016 I am new to everything and would like to learn more. What would be the best way to do this? Even if i already have some knowledge about mechanics and 2 strokes (snomow) it putted hours to read stuff here. Even if you read it once, you will not remeber everything. So take a subject of interest and read a lot about it. Your first pick is shee engine?? Then make search about ' banshee topend' or 'banshee engine' but put it that way in google: banshee topend site:wwws.bansheehq.com The bold part force google to search in bhq forum. Why?? 'cause google search engine is way better than bhq's one. Quote
trickedcarbine Posted August 15, 2016 Report Posted August 15, 2016 When you see a term you're not familiar with, try a search. IMO, the best way to search is to use google instead of the site search. For some reason it's almost always far more relevant. Try " (keyword) BansheeHQ " when searching. Quote
m671054 Posted August 15, 2016 Report Posted August 15, 2016 Look through cp industries web site. You will have more ? After that im sure Quote
m671054 Posted August 15, 2016 Report Posted August 15, 2016 http://www.cpindinc.com/they build alot of options, but there are others. After looking st everything they list you should be really confused. Quote
RagunCajun Posted August 15, 2016 Report Posted August 15, 2016 Serval for play and cub for drag racing are the two most common. You can search the Dyno section to see what kinda power they make on different strokes, bores and set ups. You can then call a builder to see which would be best for you if you are like me and don't understand how power curves translate to seat of pants. Or ask on the Facebook hq group. People will probably spoon feed you info there. Hopefully it's correct. Quote
ClaudeMachining Posted August 15, 2016 Report Posted August 15, 2016 I dont suggest to ask question on fb... 1 Quote
ClaudeMachining Posted August 15, 2016 Report Posted August 15, 2016 I posted the link to CP's different banshee cylinders on August 8th. I doubt he actually took the time to look them over to see what was different about them.Even if he does, it's too munch info for a noob. Envoyé de mon GT-P5113 en utilisant Tapatalk Quote
n2otoofast4u Posted August 15, 2016 Report Posted August 15, 2016 about 70% of that shit on CPs site is basically obsolete stuff that they no longer make unless you want to order quantity. Quote
