KamiKonze Posted July 19, 2016 Report Posted July 19, 2016 Ok... So jetting isn't my greatest strong suit.... I've been looking at the Lectron Carbs wanting to try them. But a lot of people say they are worse than regular carbs. Any thoughts on the Lectrons? Good? Bad? Sent from my iPhone using Tapatalk Quote
n2otoofast4u Posted July 19, 2016 Report Posted July 19, 2016 Gas or meth? Sent from my SAMSUNG-SM-G891A using Tapatalk Quote
KamiKonze Posted July 19, 2016 Author Report Posted July 19, 2016 Gas, 93 octane to be specific Sent from my iPhone using Tapatalk Quote
KamiKonze Posted July 19, 2016 Author Report Posted July 19, 2016 I mean I don't want to fiddle fart around with jetting all day, are the pwk carbs easier to jet? Sent from my iPhone using Tapatalk 1 Quote
KamiKonze Posted July 19, 2016 Author Report Posted July 19, 2016 And also, is there an advantage to running two carbs on a non big bore motor? Or is the dual carb setup really only for big bores? Sent from my iPhone using Tapatalk Quote
JTmachining Posted July 19, 2016 Report Posted July 19, 2016 All carbs need to be set up right to work right. Lectrons are high maintenance compared to PWKs 1 Quote
KamiKonze Posted July 19, 2016 Author Report Posted July 19, 2016 Ok this might sound dumb but aren't the PWKs the carbs with the power needle? Sent from my iPhone using Tapatalk Quote
trickedcarbine Posted July 19, 2016 Report Posted July 19, 2016 Negative. You're referring to the jet fed by a tube off the bowl, correct? Those are called power jet. Some factory 250 dirtbike carbs had them but I think they were electronic. Lectrons have power jets as well. Quote
JTmachining Posted July 19, 2016 Report Posted July 19, 2016 Lectrons have metering rod. PWK has needle Quote
KamiKonze Posted July 20, 2016 Author Report Posted July 20, 2016 Is there any real difference? Pros and cons? Sent from my iPhone using Tapatalk Quote
sheerider11 Posted July 20, 2016 Report Posted July 20, 2016 Not to be a dick, but if these are questions your asking you need to stick with basic carbs 2 Quote
KamiKonze Posted July 20, 2016 Author Report Posted July 20, 2016 I'm new to the whole 2 stroke community so I guess you are right, thanks for the honesty though. Sent from my iPhone using Tapatalk Quote
KamiKonze Posted July 20, 2016 Author Report Posted July 20, 2016 To be totally honest, I am just looking for info on which carb is best for me, and how to jet it correctly. I thought the experts here would know a bit more than I do now. Sent from my iPhone using Tapatalk Quote
Bennett131 Posted July 20, 2016 Report Posted July 20, 2016 To be totally honest, I am just looking for info on which carb is best for me, and how to jet it correctly. I thought the experts here would know a bit more than I do now. Sent from my iPhone using Tapatalk If you posted your setup, I missed it. Quote
