registered user Posted July 18, 2016 Report Posted July 18, 2016 ace hardware should have atleast 500 of those in stock im pretty sure of it 1 Quote
landonschmidt Posted July 18, 2016 Author Report Posted July 18, 2016 Awsome. I will need at least 300 Sent from my LGLS990 using Tapatalk Quote
landonschmidt Posted July 21, 2016 Author Report Posted July 21, 2016 So yamabond....can i torque the bolts to spec ad soon as i apply the gasket maker and slap the halves together? Curious as to whether i will need to redo this 1st time project Because it appeared that 90% of the yamabond squirted to the outside of the cases. Sent from my LGLS990 using Tapatalk Quote
Larry's Shee Posted July 21, 2016 Report Posted July 21, 2016 Get a plumbers acid brush (used in soldering pipes) to spread the Yammabond. Use a small disposable cup or even piece of beer box to squeeze some out. "Paint" an even coat on one half then assemble. Have to work relatively quick as it sets pretty quickly. Yeah, 99% gets squeezed out, that's why thin even coat, avoid getting it in any threaded holes. Quote
landonschmidt Posted July 21, 2016 Author Report Posted July 21, 2016 Get a plumbers acid brush (used in soldering pipes) to spread the Yammabond. Use a small disposable cup or even piece of beer box to squeeze some out. "Paint" an even coat on one half then assemble. Have to work relatively quick as it sets pretty quickly. Yeah, 99% gets squeezed out, that's why thin even coat, avoid getting it in any threaded holes. Thanks! Well i finally did a leak down before i tore it apart to reapply the yamabond, and the gauge showed 5.65psi after 6 min. I really had to work with my intakes! I did not know they were so bad!! Both intakes were leaking in about 10 diff locations. So yes as much as its been said "DO a leakdown"! I wouldve never guessed it was that bad. Glad i tore it apart to rebuild from bottom up Sent from my LGLS990 using Tapatalk Quote
landonschmidt Posted July 24, 2016 Author Report Posted July 24, 2016 Well shux.. So after assembling my cases for the 2nd time 2days ago, i just now remembered i hadn't put loctite on any case bolts/nuts. Would there be any harm in removing-loctiting-torquing "each nut and bolt" one at a time? I kinda doubt i will mess my yamabond up by doing this...but figured id ask Sent from my LGLS990 using Tapatalk Quote
ClaudeMachining Posted July 24, 2016 Report Posted July 24, 2016 Well shux.. So after assembling my cases for the 2nd time 2days ago, i just now remembered i hadn't put loctite on any case bolts/nuts. Would there be any harm in removing-loctiting-torquing "each nut and bolt" one at a time? I kinda doubt i will mess my yamabond up by doing this...but figured id ask Sent from my LGLS990 using Tapatalk Do it one at times, no problem. I dont even have Loctite on mine lol! Quote
landonschmidt Posted July 24, 2016 Author Report Posted July 24, 2016 Do it one at times, no problem. I dont even have Loctite on mine lol!Ya thanks for reply! I was debatin on wether i need it or not so i asked.. I gots me a dune ride at silver lake coming up in a couple weeks and this was my 1st bottom end rebuild and so you could say...im a bit paranoid Sent from my LGLS990 using Tapatalk Quote
m671054 Posted July 25, 2016 Report Posted July 25, 2016 No lock tight is needed on case hardware. Dont waste your time. Quote
landonschmidt Posted July 25, 2016 Author Report Posted July 25, 2016 No lock tight is needed on case hardware. Dont waste your time.Not doubting you. But just for my own knowledge gain..why is it not needed? Sent from my LGLS990 using Tapatalk Quote
m671054 Posted July 25, 2016 Report Posted July 25, 2016 I cant explain why its not needed but its not. Ive never used it in that application on probably 10 motors. Never had case hardware issues. There are tons on engine applications that dont use locktight on critical fastners. The only things that might have been locktighted in would be the studs into the upper case half in the crank area simply so they dont loosen when removing the nuts. Even thats not required. If you really wanted to you could do one at a time with no issue. Quote
BANSHEE HP Posted July 25, 2016 Report Posted July 25, 2016 I loctite the studs into the cylinders and thats it Quote
landonschmidt Posted July 26, 2016 Author Report Posted July 26, 2016 Crap. I need water jacket plugs by this weekend. Just seen that they aren't in jugs. Sent from my LGLS990 using Tapatalk Quote
ClaudeMachining Posted July 26, 2016 Report Posted July 26, 2016 Take the one from your stock one. Envoyé de mon GT-P5113 en utilisant Tapatalk Quote
