hp2000 Posted May 25, 2016 Report Posted May 25, 2016 Those seem to be SLS. You might not like them because they're going to flex on you as the side walls don't have much rubber left on them. Sent from my iPhone using Tapatalk Quote
Strm Trpr Posted May 25, 2016 Author Report Posted May 25, 2016 I couldn't pass up on the price to try out some straight paddles. If I don't like them, I'll sell them. Ahh, they are SLS's. So can I have the bead to bead buff and keep a heavier side wall for less flex? 1 Quote
hp2000 Posted May 25, 2016 Report Posted May 25, 2016 I couldn't pass up on the price to try out some straight paddles. If I don't like them, I'll sell them. Ahh, they are SLS's. So can I have the bead to bead buff and keep a heavier side wall for less flex? Yes, if you get bead to bead buff it will have more side wall for sure and less flex. Sent from my iPhone using Tapatalk 1 Quote
JTmachining Posted May 25, 2016 Report Posted May 25, 2016 Skat has many options. There's reg buff, bead to bead buff, BTB SLS...etc Quote
87sheerips Posted May 25, 2016 Report Posted May 25, 2016 9 paddle padla brat comp cuts or nothing. Quote
Strm Trpr Posted May 25, 2016 Author Report Posted May 25, 2016 9 paddle padla brat comp cuts or nothing. and a can of fix-a-flat... 1 Quote
hp2000 Posted May 25, 2016 Report Posted May 25, 2016 and a can of fix-a-flat... Usually takes more than one can per trip. Sent from my iPhone using Tapatalk Quote
Strm Trpr Posted May 25, 2016 Author Report Posted May 25, 2016 Usually takes more than one can per trip. Sent from my iPhone using Tapatalk For comp cut padla brats or skat traks? Quote
hp2000 Posted May 25, 2016 Report Posted May 25, 2016 For comp cut padla brats or skat traks? Paddla flats Sent from my iPhone using Tapatalk 1 Quote
Strm Trpr Posted May 25, 2016 Author Report Posted May 25, 2016 Paddla flats Sent from my iPhone using Tapatalk thought so Quote
lastnline75 Posted May 25, 2016 Report Posted May 25, 2016 Paddla flats Sent from my iPhone using Tapatalk Nothing like following someone around Glamis dunes with a bicycle pump in your camelback.....good times.. 2 Quote
hoppedupandcutdown Posted May 25, 2016 Report Posted May 25, 2016 HaHa, I just put about 38psi in mine last night to load it in the trailer. Just hoping they still have enough air for it to roll out Friday night. 2 Quote
87sheerips Posted May 25, 2016 Report Posted May 25, 2016 and a can of fix-a-flat... Mine are old as shit and hold air for a full day.... Couple plugs per side too... They are ragged out They perform the best bottom line!! Nothing compares 1 Quote
dave5.0 Posted May 26, 2016 Report Posted May 26, 2016 They're prob fine for that flat dunes you have up there. But they aren't really tall enough for a lot of other places. I've got a set of comp cut 9s I still run occasionally. They aren't bad. But there are better ones out there. 1 Quote
