Have 421 cub have trouble launching falls on it face when you drop the clutch out of the hole. Has 145 compression timing +6 drag port gearing is 15/42 41mm flat side mikuni carbs shearer oof pipes 65 pilot jets 260 main 6fj41 needle 2600 elevation in Canada
It's a buddies quad Matt shearer was the last one to work on it. We did a leak down test last night was good. Ya that's what we thought the pilot jet was pretty high has a build sheet on it I'll see if I can find the fourm page and post it thanks for your help
Drop the front tooth back to a 14 tooth.
Get some proper jets in those carbs. No way Shearer set those carbs up like that. You'll be around a 32.5 pilot max.
What fuel?
Edited by trickedcarbine
