thanks to s.b.r troops for ideas
1987 banshee clutch cover
paint remove
First error, use sandpaper #60 to remove the paint, i did some deep scratches, that was difficult to remove later (fuuuuck)
- #600, #2000 sandpaper
- after day, i order buffing kit
20160421_093701_RichtoneHDR_zpsuw9al8cm.
Get a new waterpump bearing, now i waiting for a seal and plexiglass
20160421_112908_RichtoneHDR_zpsbqxnnpfv.
all that can be better, but i'm don't retailer
  • Like 1
after riding test, the good (no leaks), the bad, the oil turn to milk color fuuck milk color and the water on the radiator is down, i think that i broke the seal while installing, the impeler is the same that works with the original cover and not problem with the oil, the o-ring hose between head and clutch is the same and works good before with the original clutch cover, i don't know what can be really
Edited by maggdog
