Its very simple you just put your meter across the two wires at the connector and it should look like 4 wires but only two are connected to the harness if you look inside the connector.  my Ohm meter is a Blue Point one and if I have it on continuity check it beeps if it has ohms and says OFL if it has no connection. In Ohms check it wont beep but only show the value of ohms.. Im not sure how your meter is set up..
its important that you check the switch over and over flip it alteast 20 times and make sure it has a connection every time its ON
I ment testing the on/off with head light switch
And continuity cuts out on on position
If i wiggle it n the off position it cuts out continuity
take apart the handle bar control switch housing and look inside at what color wires go to the Kill Switch.. there is probably a bunch of dirt in there too i imagine.. i know from experience.. clean it out ..
If its always having continuity in ON every time i would use the switch.. but they are really cheap to buy an aftermarket one like less than $10
And is there a way to just bypass and see if its that so i could b
back probe the harness connector with a paperclip to make the connection.
Edited by FasterThanU90
So on position NO continuity
And off pos continuity
thats backwards from what it should be at the main switch..
He's testing the fucking thumb switch, already has the key switch bypassed
sounds like hes getting some weird readings at the thumb switch
No
He is somehow getting no continuity to ground in the off position occasionally. Thats not wierd ?
not occasionally, every time, that's how a Banshee shuts off via the thumb switch - by completing a circuit to ground from the black/white wire.
Thats what he said dude and i know how the switch works
