R.R-1.1993 Posted February 11, 2016 Author Report Posted February 11, 2016 No luck im going to try ohm reader tomorrow Is there a way to test if stator is good??? Not just it reading numbers on ohm reader Quote
Larry's Shee Posted February 11, 2016 Report Posted February 11, 2016 No luck im going to try ohm reader tomorrow Is there a way to test if stator is good??? Not just it reading numbers on ohm reader Ya, you swap it for one that you know works. Quote
Larry's Shee Posted February 11, 2016 Report Posted February 11, 2016 Go to technical forum, thread titled "Banshee electrical FAQ" by member Tedd1. Everything ya need to know right there. Quote
Larry's Shee Posted February 11, 2016 Report Posted February 11, 2016 You're fucking welcome. 2 Quote
hoppedupandcutdown Posted February 11, 2016 Report Posted February 11, 2016 Go to technical forum, thread titled "Banshee electrical FAQ" by member Tedd1. Everything ya need to know right there. HaHa, beat you to it, already provided a link to it yesterday! Lmao Quote
Larry's Shee Posted February 11, 2016 Report Posted February 11, 2016 Well fuck me running. Probably saw, but didn't click it. This caveman hasn't figured the copy/paste thing on this tablet I'm using. OP, test in Clymers for ign coil is wrong, test POS to neg on primary, plug wire to p.wire on secondary Quote
R.R-1.1993 Posted February 12, 2016 Author Report Posted February 12, 2016 Thanks fellas i ohmed out everything it checked out good I checkd all wires for continuity and everythings good My old stator fired up good and ran good so doesnt that mean its good This other i put fired up to so either both stators are fukd or im missin something Quote
R.R-1.1993 Posted February 12, 2016 Author Report Posted February 12, 2016 Do all grounds go together?? The previous owner gots all grounds linkn to eachother Like there isnt one thats suppose to go to a certain wire?? Quote
hoppedupandcutdown Posted February 13, 2016 Report Posted February 13, 2016 All the ground wires gang together there in the middle of the harness. Quote
hoppedupandcutdown Posted February 13, 2016 Report Posted February 13, 2016 Is it possible to have spark but not see it I sware i kikd it while thumb on top of plug and it gave a lil shok??my buddy tried it to said definetly pulse I don't know what you're doing there, it should actually hurt. Pull a spark plug, stick it in the boot, hold it's metal part on the engine's metal, kick, look for a bright blue spark. Helps to be in a room with little light. Quote
R.R-1.1993 Posted February 13, 2016 Author Report Posted February 13, 2016 It did shock the hell out of both of us But goes away Quote
hoppedupandcutdown Posted February 13, 2016 Report Posted February 13, 2016 The pain, yes it all eventually goes away. Quote
R.R-1.1993 Posted February 13, 2016 Author Report Posted February 13, 2016 The spark i ment You get zapped couple times then nothing put it on ground on block and nothing Quote
hoppedupandcutdown Posted February 13, 2016 Report Posted February 13, 2016 You just would have to have a loose connection somewhere. Either at a factory plug or something that's been previously cobbled. Quote
R.R-1.1993 Posted February 21, 2016 Author Report Posted February 21, 2016 I got a new stator today still didnt do shit So what can be next thing to check I almost got all new electrical system but the harness itself Quote
