Banshee bogging in gear but neutral is fine
Matchstick
Hey I'm kinda new to the two stroke world, and my banshee won't even get close to revving high in gear but in neutral it's fine . I had this problem before and I replace and gapped the plugs, and clean the filter and worked, so I tried this again and it's not working. Any suggestions. I have a tors delete on it also. Thank you.
Plug boots are cheap, and many times electrical stuff that's going bad won't show as being bad, until that part starts to get some heat in it.  You keep asking for ideas, but when people tell you to do something, you say that the parts are good.  You've got to listen to these guys, if you want to get it running right again.
