Matchstick
Everything posted by Matchstick
  1. What’s the best air filter set for desert and dune riding, I’m currently running an air box with a pro flow adapter and a k&n filter with an outerwear. Sent from my iPhone using Tapatalk
  2. . What could detonation in only one cylinder. Sent from my iPhone using Tapatalk
  3. What caused my piston to do this? Detonation? Lean? Or just old. Sent from my iPhone using Tapatalk
  4. I need to get a set reeds and was wondering what you guys recomend. 02 banshee T5 pipes
  5. I have listen I've done everything they have said. Nothing has changed
  6. Wires and spark is all good
  7. Any suggestions on what that electrical issue is?
  8. No water, the wash is in the desert
  9. I was riding through a wash on the way back to camp and out of no where it bogged down and wouldn't let me go any faster
  10. The tors is deleted, and no I didn't know there was a parking break delete
  11. I cleaned the carbs and all that, it is still bogging
  12. The plugs are where black and wet. It started doing this out of nowhere. It started acting up likes this when I was heading back to camp after a ride.
  13. Hey I'm kinda new to the two stroke world, and my banshee won't even get close to revving high in gear but in neutral it's fine . I had this problem before and I replace and gapped the plugs, and clean the filter and worked, so I tried this again and it's not working. Any suggestions. I have a tors delete on it also. Thank you.
  14. Hey I'm kinda new to the two stroke world, and my banshee won't even get close to revving high in gear but in neutral it's fine . I had this problem before and I replace and gapped the plugs, and clean the filter and worked, so I tried this again and it's not working. Any suggestions. I have a tors delete on it also. Thank you.
  15. Hey I'm kinda new to the two stroke world, and my banshee won't even get close to revving high in gear but in neutral it's fine . I had this problem before and I replace and gapped the plugs, and clean the filter and worked, so I tried this again and it's not working. Any suggestions. I have a tors delete on it also. Thank you.
