The bike wasn't working when I got it had a bad stator I fixed it and now only this. It has Athena 392 big bore kit and bills pipes with stock carbs and reeds. Not sure what size pilot jets or any jets are in it
Clean carbs thoroughly, see what size pilot you have. you want to go up one size at a time OR clean the ones you have if they have been changed to a 27.5 or 30. Stock pilot is 25. You need to see what size main is also.
My banshee was running good when I wreck it only one cylinder is working how do I fix it
Sent from my Z813 using Tapatalk
Well first you have to start your own thread.
Welcome to BHQ
Welcome to BHQ
How do i do that im new to all this new tech i been locked up for a long time someone wouldnt mind helping a brother out how to get my important question answered
Ok I changed my pilot with a 30 and still have the same problem. When I first start it after sitting a day it won't start unless I cover the carbs and kick it a few times then it will start right up and run great. Once I start it it idles good and runs good. Need help what could it be
