Mandolezama
Everything posted by Mandolezama
Before I had to cover the carbs to get it started because it was sucking air from somewhere else and then it would run fine after I got it started. After I fixed the air leak it would run fine just wouldn't idle. I adjusted the air screw but I think I might have forgot to adjust the idle screw. So I will put the 25 pilot back in and adjust the idle screw and see what happens because with the 30 it's getting to much gas causing it to flood Sent from my iPhone using Tapatalk
Was leaking air now I fixed the air leak it held 6psi for over 30 min. Now when I start it for the first time of the day it's floods. I switched my pilot from 25 to 30 I think I may have went to big. Mods are Athena 392 kit, stock carbs with 320 main and now 30 pilot, bills pipes and boysen reeds Sent from my iPhone using Tapatalk
Had the same problem on mine. I was missing the lock but I put a nut on it adjusted it and tightened the nut with lock tite been good ever since
Not sure what size jets are in it now it had all this when I bought the bike
I'm new to this website been using it a lot. I have a 99 banshee with Athena 392 big bore kit and has bill pipes has stock carbs and reeds need help with what size jets to use
