This is how I bought it July 4 2014, at the end of summer it was at 100 psi per cylinder, wiring harness was melted from previous over putting a turbo heater on the motor and forgetting about it, and was a all around turd due to the improper jetting.
So after a few hundred dollars later I built a hopefully bullet proof motor.
> redline shaved the head
> cylinders bored to 64.50
> wiesco top end kit
> stock porting just cleaned up
> carbon tech lt reeds
> transmission was disassembled and inspected my myself, replacing parts worn out of spec. Along with fresh bearings.
> F.A.S.T hooked me up with a easy spring and a modded shift shaft
> I did the shift star mod myself
> billet clutch basket with mattoon backing plate I added
> drive line standard HD clutch kit
> mattoon lockout cover for future plans
> mattoon adjustable timing plate
> billet water pump cover, impellar and vent block off
> FMF fatty's with shortened cans
The local powder coater did all my parts white after repairs where done to the cracks, I went with a cfm airbox for the stock carbs, alba long travel-standard arms, all new pivot works bearings, and a water proof, shock proof, dust proof wiring harness
And that's what she looks like almost completely done
Its a fun build even though my bank account says other wise
I like it for the fact it looks built to be ridden hard as fuck on Saturdays on wrenched on, on Sundays...repeat.... just my style.
Looks great. Think the PC will last n the cans? Or is it hi-temp?
Sorry, but you really should ditch the boost bottle.
I'm experimenting with the cans, its regular powder coat. And yes I agree on the boost bottle, there is to many options and I'm not sure which one to take yet lol
nice work, replace the boost bottle with a factory crossover or a hose with a spring over it, a nice clean white hood and rad shroud might look really good...might not
  • 3 weeks later...
