BANSHEE HP Posted December 24, 2014 Report Posted December 24, 2014 Same cylinder for 110 or 115 rod, different gasket and pin height piston. I never knew they cast a 120 or even a 125 rod 10mm cub. I doubt many if any are around. This piston replaces the current most commonly used piston, the 573mo6800... used in 58, 61 and 64mm strokes with a 115mm rod. Quote
registered user Posted December 24, 2014 Report Posted December 24, 2014 Same cylinder for 110 or 115 rod, different gasket and pin height piston. ok that makes perfect sense. thats what i was trying to say in my earlier posts but i probly made it sound confusing. so theres just one cylinder and its cast for a 110 rod. i understand now and hence the reason you made the new piston, to accomidate the 115 rod without needing a spacer plate I never knew they cast a 120 or even a 125 rod 10mm cub. I doubt many if any are around. they might not cast a 10cub for 120 or 125 rods. it shows them listed on the site however but im thinking theyll just send you a 10cub cast for 115 rod and then if you choose to use a longer 120 or 125 rod youll either have to use a spacer or a different piston with a higher pin Quote
m671054 Posted December 24, 2014 Report Posted December 24, 2014 Look on the site again. In the more details for each size it list all cylinder dimension and rec piston and gaskets. If you pay attention to the cylinder height it clearly shows different cylinder sizes. i dont think its one casting decked to fit all. Quote
rubberneck Posted December 24, 2014 Report Posted December 24, 2014 ok that makes perfect sense. thats what i was trying to say in my earlier posts but i probly made it sound confusing. so theres just one cylinder and its cast for a 110 rod. i understand now and hence the reason you made the new piston, to accomidate the 115 rod without needing a spacer plate Im not sure what the original intended piston and rod combo the cylinders were cast for, it seems it is most likely the 115mm rod though. The most common combination seems to be the 115mm rod with .012 base gasket using the currently available blaster pistons. (this is for a 58/68 motor) At least thats the way all 3 of my 421 cubs and servals were set up. they were purchased from different vendors at different times over the years so it seems that is the "standard" so to speak. If you look on the CPI site, they have 58x68 cylinders listed for both the 110mm and 115mm rod, but when you open them up they are in fact the same cylinder they just list a different piston and base gasket if you use a 110 mm rod. That part i think you already figured out. The blaster piston commonly in use already has the higher pin height that this new piston has. Im gathering the differnce is mostly in the windows and the other mentioned improvements. Dimensionally its the same as what has been in use. So basically we arent using a spacer plate now and we wont be with the new one, its just an "improved version" 2 Quote
dave5.0 Posted December 24, 2014 Report Posted December 24, 2014 Rubberdicks interpretation made more sense than registered user dudes. His didn't make sense. Seems he's the one that doesn't know what he's talking about being it clearly states what's up with these new pistons in the beginning of this thread. "New piston option for 68mm bore cylinders with a 6mm higher pin height like the 573mo6800 (blaster piston)." Quote
rubberneck Posted December 24, 2014 Report Posted December 24, 2014 Yep confirmed with BHP, if you already have a motor using the 573 blaster pistons (for instance a 4,7 or 10mil cub with 115rods) this is a 100% drop in replacement, just improved. Quote
possum Posted December 24, 2014 Report Posted December 24, 2014 I dont think this was very hard to understand from bhp's first post. 4 Quote
registered user Posted December 24, 2014 Report Posted December 24, 2014 says the guy thats never done a ounce of his own engine work . run along parts changer . i was trying to say the same thing rubber neck did but i couldnt type it correctly so it probly didnt make sense. all any of you geniouses had to say from the very begining was: this new piston compensates for the length difference when a 115 rod is used in a 110 cylinder. yet you clueless fuks didnt say nothin. probly because you dont know nothin. banshee HP i understand now. problem is i havent been around banshees that long so im not yet familiar with all the possible cylinder, rod, piston combinations. i think what caused confusion for me at the begining was i thought the cylinders were cast for each length of rod which had me wondering why you would need a different pin height. once i realized the cylinders werent cast for each different rod length then your new piston made sense Quote
possum Posted December 24, 2014 Report Posted December 24, 2014 ffs, well most of us already know what 573 series pistons do, and what they are for. So when Bhp said, these new pistons replace the 573s, most of us know what they are compatible to just by reading his first post. Dont respond until you go buy some clues! Quote
dave5.0 Posted December 24, 2014 Report Posted December 24, 2014 for someone that claims to do their own engine work, you are a huge fucking moron. by huge, i mean skeeter huge. for calling other clueless, you sure don't have a clue to stand on yourself. It's painful, but im goin to agree with zilla Quote
trickedcarbine Posted December 24, 2014 Report Posted December 24, 2014 It's painful, but im goin to agree with zillaDitto. Quote
sprinklerman Posted December 24, 2014 Report Posted December 24, 2014 Bunch of parts changers ^^^^ Quote
dave5.0 Posted December 25, 2014 Report Posted December 25, 2014 I'm not really into "changing" parts. I prefer to let them wear out to the point of disintegration and then I just put another quality preowned one on that I lowballed some Douche for. 7 Quote
hp2000 Posted December 25, 2014 Report Posted December 25, 2014 I like your style.... Lol Sent from my iPhone using Tapatalk 1 Quote
