10mil serval. Are they just as reliable as the 4mil?
^ that's because when you compare a 4mm stock cyl with Dune type porting on race gas, for only a couple hundred more bucks you get the same performance on pump gas out of a serval. Now make that a race gas serval and the serval is way ahead. If you drag or ride mostly wide open in the dunes, a cub is definitely the way to go.
