ryanrogers Posted October 21, 2014 Report Posted October 21, 2014 my banshee isn't firing in the left cylinder. vf4 reeds, pro circuit pipes, shaved head, and k and n pods other than that motor is stock. has 155 psi in both cylinders. i tried switching the coil wires on the plugs and it didn't change. any help would be greatly appreciated thanks Quote
Surfrjag Posted October 21, 2014 Report Posted October 21, 2014 sync carbs clean pilot jets report back Quote
ryanrogers Posted October 21, 2014 Author Report Posted October 21, 2014 if i put the choke it seems to help it and at high rpms it seems to be ok so the pilot makes sense thank you Quote
RadarRacing Posted October 21, 2014 Report Posted October 21, 2014 Carbs put on wrong sides makes em do that. Left on right , right on left. Quote
02Bansheeee Posted October 22, 2014 Report Posted October 22, 2014 One of your reeds might be broken or chipped. Check those out while the carbs are off. 1 Quote
ETR174 Posted October 24, 2014 Report Posted October 24, 2014 Had the same problem but on the right cylinder, the screws loosened and the reeds were bad. Quote
