hoppedupandcutdown Posted June 17, 2014 Report Posted June 17, 2014 Did you install TORS eliminator idle screws ? Are you referring to the air screws at 1.5 out? If it won't idle, turn the idle up... Quote
350shee01 Posted June 18, 2014 Author Report Posted June 18, 2014 I do have them installed and yes, I'm referring to the idle screws. Also, I'm asking about what I have installed now. My pipes should be here tomorrow hopefully and then I'll try and adjust it to the FMFs. Quote
hoppedupandcutdown Posted June 18, 2014 Report Posted June 18, 2014 Maybe it's just me that's confused, but I would just turn the idle up. Quote
350shee01 Posted June 18, 2014 Author Report Posted June 18, 2014 I'll try and post a video tomorrow if I can't get it fixed of the problem so you can visibly see and hear what I'm talking about. Right now I'm at work and the video won't load due to the size of the file. So I'll be back on here tomorrow later on and post the video. I'll take all these suggestions given to me thus far and go from there. Hopefully one will work and I can go riding at Little Sahara this weekend. Thanks for all the input so far. Like I said, I'll get back with everyone and everything tomorrow including a video (hopefully) and I (we) can go from there. Quote
350shee01 Posted June 18, 2014 Author Report Posted June 18, 2014 Here's a short video of what's going on Quote
350shee01 Posted June 18, 2014 Author Report Posted June 18, 2014 And I just got my FMFs in and gettin ready to install them. Quote
03DMshee Posted June 18, 2014 Report Posted June 18, 2014 Judging by video (which im assuming isnt you) pilot is lean needing choke to stay running... Quote
hoppedupandcutdown Posted June 18, 2014 Report Posted June 18, 2014 Those ain't stock pipes in the video... Are you calling the air screw the idle screw? <<<Anyway, I ride Waynoka with T5's, K&n, no lid, cool head, 25 pilots and 280 mains and it's a little rich, at these temps but that's OK with me. FYI Quote
350shee01 Posted June 18, 2014 Author Report Posted June 18, 2014 Well the guy I got it from said they were stock. So I assumed they were because they didn't have any markings on them. And now that I have my FMFs on there, the left side is getting hotter than the right alot faster. And I'm calling the TORS delete idle screw and the A/F screw the air screw. So now that one sides getting hotter than the other and it won't run without the choke, do I need to change my pilot and mains? Quote
hoppedupandcutdown Posted June 18, 2014 Report Posted June 18, 2014 You will be fine with your 27.5 pilot and a 280 or 290 main. You NEED to check for an air leak. Turn your idle up. There is no way to measure 1 1/2 turns out on the IDLE screw. Quote
350shee01 Posted June 18, 2014 Author Report Posted June 18, 2014 I checked for it and there's no leaks that I found, and ok. I'll go get some new mains today. Quote
hoppedupandcutdown Posted June 18, 2014 Report Posted June 18, 2014 How long did it run with those pipes and the small mains? It could be the cold side thats the problem, do a compression test. Quote
350shee01 Posted June 18, 2014 Author Report Posted June 18, 2014 I only ran it once after I put them in and I rode maybe an hour. I've done a compression test and both are at 135psi. I just went and got new pilots and mains. I got a 30 pilot and 290 main. Andy at No Limit Power Sports suggested them for what I'm running. I also got a tap & dye set to retap the carbs. Andy said my TORS delete screw was jumping threads and it needed to be done. So after I get all of that done, I'll let you know what happens. Quote
Nightmare Posted June 19, 2014 Report Posted June 19, 2014 Those are CPI, why would you swap those for FMF? Sent from my XT1080 using Tapatalk Quote
350shee01 Posted June 19, 2014 Author Report Posted June 19, 2014 I didn't know what they were. I've never seen or owned CPI. The guy I got the banshee from said they were stock. Quote
