Stonytony Posted January 31, 2014 Report Posted January 31, 2014 Well I'm in a bind here. I got a set of jugs 68mm bore with porting for stock stroke. I want to upgrade to a 4mil. If I use the 2mil plate to get the top of the ports right. I would then lower the bottoms of all the ports by 2mm? Looking at this theory alone would that work. I know the plate corrects the tops of ports timing but then piston is goin 2mm lower then the bottoms of the transfer ports. So lowering those by 2mm would be in theory the same as fresh jugs ported 2mm up and 2mm down. Then of course porting for sand/drag. Quote
Stonytony Posted January 31, 2014 Author Report Posted January 31, 2014 Just thought I would have to lower them by 4mm? Quote
Stonytony Posted January 31, 2014 Author Report Posted January 31, 2014 Just thought again. Use the blaster piston and it's 2mm smaller from wrist pin to the top of the piston. Then only have to lower the ports by 2mm with the 2mm plate. Quote
LCW Posted January 31, 2014 Report Posted January 31, 2014 I would just send em to a sponsors and have it done right. You would need 4mil domes also. Quote
Stonytony Posted January 31, 2014 Author Report Posted January 31, 2014 So could already drag ported jugs be used with a 4 mil if I send them to rdz to have the ports corrected for the stroke? Quote
registered user Posted January 31, 2014 Report Posted January 31, 2014 just send it all to sprinklerman racing. he will get it whipped into shape for ya. porting and measure your jugs. the whole enchilada Quote
sprinklerman Posted January 31, 2014 Report Posted January 31, 2014 just send it all to sprinklerman racing. he will get it whipped into shape for ya. porting and measure your jugs. the whole enchilada Yaaay!!! I have a stalker! Sent from a van down by the river Quote
sprinklerman Posted January 31, 2014 Report Posted January 31, 2014 And I'm glad "registered user" FINALLY posted some proof that he's actually ported a motor... win/win! Sent from a van down by the river Quote
special06shee Posted February 1, 2014 Report Posted February 1, 2014 Omg. Was that "ported" with a chisel? Quote
fappy'97 Posted February 1, 2014 Report Posted February 1, 2014 Omg. Was that "ported" with a chisel? Nope, sawzall blade in a rotary grinder. 1 Quote
Young Guns Racing Posted February 1, 2014 Report Posted February 1, 2014 Flat file and rat tail ftw! Quote
sleeper06 Posted February 1, 2014 Report Posted February 1, 2014 Give some measurements from deck to top of port and I can let you know if it's doable picks help also Quote
trickedcarbine Posted February 2, 2014 Report Posted February 2, 2014 And I'm glad "registered user" FINALLY posted some proof that he's actually ported a motor... Sent from a van down by the river Wrong, last month registered user established that the work in those photos was mine. And now here he is taking claim on my most A1 work. Quote
Stonytony Posted February 3, 2014 Author Report Posted February 3, 2014 This is what I'm working with http://s1360.photobucket.com/user/Tony_Olmstead/media/Mobile%20Uploads/image_zpsb5306317.jpg.html?sort=3&o=0 Quote
