Newcs222 Posted January 12, 2014 Report Posted January 12, 2014 I've recently done a new motor install. I painted my frame and forgot to sand the areas where the motor makes contact with the frame. Now I'm getting weak spark. Whats the best way to ground the motor to the frame? I don't wanna loosen the wrong nut and get leaks. Quote
Finch Posted January 12, 2014 Report Posted January 12, 2014 ive never sanded anywhere on my frame should be grounded threw the harness and unless your filled the threaded holes with paint its ground threw every bolt hole 1 Quote
n2otoofast4u Posted January 12, 2014 Report Posted January 12, 2014 <p>One heavy gauge wire from one of the center head nuts routed to a sanded area of the frame where the coil mount bracket is.</p> Quote
trickedcarbine Posted January 12, 2014 Report Posted January 12, 2014 http://bansheehq.com/forums/index.php?showtopic=164219&page=1 Lots of photos of frame/motor grounds. Some are pretty clean looking. Quote
sheerider11 Posted January 12, 2014 Report Posted January 12, 2014 One day I will get around to shortening it. But I got mine at Walmart. It was in the auto section. It was a starter ground wire, it cost like 4 bucks. Quote
