Sent from my shed.
How's the stance with tires on ?
Since it took me like 2 hours to get the old arm off I called it a night once I got to this point... Will finish tomorrow
should use normal skid plates, should use the one JDS makes for the sprocket and rotor.
Well unlike yourself, im not a nutswinger and the factory skid does its job just fine. I dont feel the need to spend the money on his custom guards at this point. Thanks for your input tho.
solution to future problems... grease zirt on pivot tube..
on another Q.. how in the fuck did you not pooch the needle bearings.... never taken off since 2008?  shit I need to change my needle bearings every couple seasons if I TT enough lol
They were in rough shape. And a zirc is not the answer, the problem lies on the inside of the inner sleeve/bolt interface.  The way to service this is to remove your swinger once a season, take everything apart, and grease it.
The fixed style skid does work, just is a PITA in sand and other loose surfaces where it can actually get you stuck.  I will add tabs upon your request to any arm, an additional $20.
  • Like 1
ah gotcha jd... my shit never really stays together long enough to go that far anyways  :flush:
yea man I was scared this was going to happen and sure enough it did... Its my fault.
Since when is preferring a superior product considered "nutswinging"?
Sent from a van down by the river
  • Like 3
The factory skid is good?
ya it does its job just fine on my bike. I dont ride sand in ny, so never had a problem with it getting me stuck.
I know these are new and probably only a handful of guys has one, but have any of you had a chance to beat the ever living shit out of one of the HD units yet?
i plan on putting this between 2 concrete bricks and parking my truck on it........also heating up with torch then doing the same thing. ill have a review shortly
That should do it.
