A lot of lag in the begging of gears
b.rich108
I just picked up a 97 from a guy for pretty cheap in my opinion $1100.  It is very hard to start from a stop.  No matter how much I slip the clutch and how much gas I give it, when I start to move the rpms drop and the bike almost stalls out.  I have been riding 4 strokes all my life.  Is this the way all banshees are?  It is the same in every gear.  When I shift up a gear and hammer it, it almost seems like it bogs out then it gets going then boom hits the power band.  I am not sure of the gearing or if that will cause the issue that I am having.  I am wondering if the carbs not being jetted correctly or maybe not being in sync would cause this?  Could lack of compression be the issue?  The guy told me it has about 6-8 hours on the rebuild.  He said it's .40 over, the pistons, jugs, rod and bearings, and head are all new.  Mod quad cool head, and hi flow billet water impeller, boost bottle, 2 into 1 air filter and I think the rear tires are 21".  Any help would be very much appreciated.  Thanks
Since you already have these questions you can answer some of them yourself with a compression check and by looking at what jets you have and checking the sync on the carbs.
Report back with your findings and some one could probably tell you what you need to know then.
No its not normal but as to why its hard to say without more info. If it dies have bigger carbs it could be they are too big for a stock motor. Like I said tho hard to say without more info
