Save some $$ to put elsewhere. IMO you pay to much for the Hinson name. Contact an HQ sponsor for a billet basket. We've used Magnums from Jeff @ FAST Racing on our asphalt bikes for years and they've held up 100%.
I got a gift card to one of my local shops here for $300 bucks I was just gonna order it from them...they go threw Hinson for products
Sent from my iPhone using Tapatalk - now Free
Edited by Abel138
If your stuck on using hinson parts dont be worried about the spring loaded one. im running 3 of them 2 bikes easily over 100hp with no issue. the only thing is your stuck with their ratio straight cuts. with the cushion basket you can run any ratio but i feel the same as others, your paying for the name.
  • 5 months later...
only baskets that have held up in my motors are the big anodized matton's  or the spring loaded hinson.  any other basket and i at least convert it to a big bolt, thick plate, mattoon cusion basket.  every other one i have ripped the bolts out of or blown the cusions out of them.
if you run the spring loaded you will most likely have no problems related to clutch basket failure.  its a good choice.
  • Like 1
  • 4 weeks later...
my questions is when do u really need to use a billet clutch basket, 421, 10 mil, 18 mil????
I ran a billet basket in my 350 until I got the Hinson.
Sent from my HTC One_M8 using Tapatalk
Any time the stock basket in a bike is finally worn it should be replaced with a quality forged unit. The Magnum/PE basket is what, 150ish now. Wonder what a new OEM costs since you have to buy them with the gear attatched.
