sprinklerman Posted December 11, 2013 Report Posted December 11, 2013 pour it on a hard surface and whack it with a hammer..the shit will combust! smart assWhy would anyone want to do that? Quote
m671054 Posted December 11, 2013 Report Posted December 11, 2013 See if you can source propelyne oxide locally. vp used to sell it. Mix 1gallon to 4 alky. Slightly easier than nitro. highly rec looking into the hazardous health affects of all power adders. Quote
DUSTY05 Posted December 11, 2013 Report Posted December 11, 2013 Why would anyone want to do that? because turbochassis dont seem to think it will do anything...it is highly dangerous under pressure Quote
sheerider11 Posted December 11, 2013 Report Posted December 11, 2013 pour it on a hard surface and whack it with a hammer..the shit will combust! smart assProve it Quote
DUSTY05 Posted December 11, 2013 Report Posted December 11, 2013 Good way to make a hammer disappear. Thank you Quote
dozer Posted December 11, 2013 Report Posted December 11, 2013 Can be used effectively and safely. More than 1 way to skin a cat. interested in more info from you. the only person i know thats tried it melted a few pistons and gave up. Quote
RobertR Posted December 12, 2013 Report Posted December 12, 2013 Hum nitro in the serval now that would be fun and a quick way to get a new motor. Quote
dragbanshee98 Posted December 27, 2013 Report Posted December 27, 2013 i have been running nitro powered RC cars as a side hobby for years now, and i have always thrown around the idea of trying it in my drag quads. if i can get 6-10 gallons of 20/80 nitro/alcohol mix in those, then whose to say you cant make a larger, more well built engine do the same? or even last longer? only thing that has stopped me to this point is the fact that my quads only run race gas at this point and i dont see it worth the switch to an alcohol setup just simply to "try it out" Quote
WINDYCITYJOHN400 Posted December 27, 2013 Report Posted December 27, 2013 i have been running nitro powered RC cars as a side hobby for years now, and i have always thrown around the idea of trying it in my drag quads. if i can get 6-10 gallons of 20/80 nitro/alcohol mix in those, then whose to say you cant make a larger, more well built engine do the same? or even last longer? only thing that has stopped me to this point is the fact that my quads only run race gas at this point and i dont see it worth the switch to an alcohol setup just simply to "try it out" Sounds so simple right? Stand up. Now lift your left foot up and grab it with your left hand and hold it up. Now just do the same thing with your right foot and you'll be floating. Sounds simple right? Kinda like thinking nitro is simple. Quote
n2otoofast4u Posted December 27, 2013 Report Posted December 27, 2013 Sounds so simple right? Stand up. Now lift your left foot up and grab it with your left hand and hold it up. Now just do the same thing with your right foot and you'll be floating. Sounds simple right? Kinda like thinking nitro is simple. LMAO....... Quote
sprinklerman Posted December 27, 2013 Report Posted December 27, 2013 ....nitro methane...so easy an RC car can run it. Just put it in your tank an go! Quote
n2otoofast4u Posted December 27, 2013 Report Posted December 27, 2013 ....nitro methane...so easy an RC car can run it. Just put it in your tank an go! Exactly! Just splash the tank with it and go. Whats the worse that can happen? Quote
dragbanshee98 Posted December 27, 2013 Report Posted December 27, 2013 Sounds so simple right? Stand up. Now lift your left foot up and grab it with your left hand and hold it up. Now just do the same thing with your right foot and you'll be floating. Sounds simple right? Kinda like thinking nitro is simple. i was never stating that nitro was simple, i know it is not. nitro is highly corrosive if not purged OFTEN. it can destroy fuel lines fairly easily, loves to rust pistons, and burns HOT to say the least. that and 20% is going for around 40$ a gallon last time i purchased it.. i was never saying it would be easy to run nitro in a quad, hell its not even easy to run it in the RC cars specifically designed for it. the way i see it though, if challenges were easy, would they still be called a challenge? Quote
WINDYCITYJOHN400 Posted December 27, 2013 Report Posted December 27, 2013 You want a challenge? Solve autism or repeal Obamacare. Nitro in a quad with your level if experience will just drive aluminum costs up nation wide. 1 Quote
