First of all hope every one had a good "Thanksgiving day".
The problem:
The right cylinder seems to not be working properly.
You can hear the left pipe but no the right pipe. If you put your hand like a feet from the silencers you can feel the back pressure on the left but on the right is almost no pressure and cold. When I rev the bike, half way it just stays revved up.
Mods I have done recently:
Like a month ago I removed TORS system (everything) and installed Motion Pro replacement system with new throttle cable. I initially synchronized the carbs by eye.
Yesterday I installed new VForce4 reed cages.
Lubbed the throttle and clutch cables.
A little story:
Riding the bike after the TORS where removed seem to be ok. At some ATV event a guy told me my bike may have carbs out of sync because he heard the left pipe but the right pipe did not sound the same. He showed me the problem by revving the bike a little and the back pressure on the left was good but the right came to life after more the 1/4 throttle .I rode the event and the bike performed ok but not good and I had on the back of my mind what the guy told me about the carbs. SO I called FAST and bought the carb sync tool and VForce4.
After installing the VForce4 I started to sync the carbs but the bike just stayed revved and I had to shut everything down.
I checked the carbs, the reed cages,  the throttle cable but everything seems to be ok.
I thought it was jetting related so I put the needle jet in the 4th position. I fired up the bike again but the right pipe is working colder and the bike stayed revved up.
Bike Mods:
FAST (NOSS) Cool Head with 20cc dome... last time I checked compression was 150 psi
Timing plate +4
CPI small bore inframe drag pipes
TORS Removed
stock 26mm mikuni carbs jetting (Pilot: 27.5; air screw: half turn out; needle jet: 4th notch; main: 300)
I will take the right pipe out, check compression and maybe take the cool head out to see the right cylinder.
Any ideas?
I'm still having issues with the bike revving up.
The rubber choke between the carbs is correctly installed.
I have checked the compression of the cylinders an it is at 145 psi each.
Took right pipe out... does not seemed to be plugged, damaged... nothing.
I have sprayed carburator cleaner around the gaskets in the reed cages, the carbs, while the bike was idleing and found no air leak. As far as I know if there was some kind of air leak around those areas the bike would have revved higher... did not happened.
I did notice the right side is working a little better, had to turn air screw all the way in (may have to get 30 pilot).
Bottom end seems to be improved and it wheelies when I throttle the bike.
I have switch coils and still the same issue.
I will keep trouble shooting it.
I have a video of the problem on my U tube page.
I'm sure the throttle cable is not sticking.
Even though the carb slides are not shown I KNow they are not stinking because the same situation happened when I tried synczing the carbs and the slides were all the way down.
In the video you can see the even when I turn the switch to the off position the bike stays revved consuming whatever full is left.
I was able to kill it by putting the bike in gear and slowing releasing the clutch.
Please advise.
that same thing happened to my friends cub when we tried these carbs that he had. we got it to shut off after covering the carbs with our hands and choking the bike. haha my buddy was shitting bricks when it woudnt shut off. put some pwk carbs in and problem solved.  more then likely something is up with the carbs... jetting might not be clean ect
My 4mill does the same thing at idle...left side doesn't puff any air out just a lil smoke until I pick the throttle up but it runs awesome and has crisp throttle response....just idles funny is the only prob...i have pwk 35 w/ after market idle screws is what I blame mine on
I seen alot of bikes hang open like that on alky but not gas...i guess there's enuff heat in there to burn gas after spark maybe
