moledigger Posted November 27, 2013 Report Posted November 27, 2013 Any 1 Running This Setup. What Did You HaveTo mod To Get It To Work? Quote
sleeper06 Posted November 27, 2013 Report Posted November 27, 2013 Yes done it plenty moved air box back blue turbo hose to extend rubber boots make some brackets to bolt air box back in Quote
moledigger Posted November 27, 2013 Author Report Posted November 27, 2013 Did You Cut The Forward Airbox Mounts Out? Quote
sleeper06 Posted November 28, 2013 Report Posted November 28, 2013 Yes and I also cut the plastics to slide the box back and ditch the. Overflow bottle Quote
SAVAGE420 Posted November 28, 2013 Report Posted November 28, 2013 I use a box with 35s. I use some larger hose cut to length and clamps. Cut the metal frame mounts off. Zip tied the rear of the box to the frame. Is nice and solid and I've had it this way for years. There was a thread on here a while ago about this that I posted some pics in. If you can't find it I'll try and post them again. Quote
SAVAGE420 Posted November 29, 2013 Report Posted November 29, 2013 Did you find the pics I posted awhile back? Quote
trickedcarbine Posted November 29, 2013 Report Posted November 29, 2013 That's the thread. http://bansheehq.com/forums/index.php?showtopic=166557 Gotta love google Quote
jbooker82 Posted November 29, 2013 Report Posted November 29, 2013 UPP makes adaptor hoses to go between the carb and air box. Quote
moledigger Posted November 29, 2013 Author Report Posted November 29, 2013 Yeah I Have Them. The Alignment Is off. Quote
