moledigger
    2003 se F.A.S.T Dune/Play Port, Noss Head 20cc, +4 timing, stock carbs 310 main 27.5 dynojett needle ?, Mgnum Basket with F.A.S.T clutch setup.
Recent Profile Visitors
moledigger's Achievements
  1. Anyone here repack their 916 silencer with anything other then the kit they have online? Its the 2597-20 kit. Guess I need 2 kits since its 2 silencers in 1. DMC doesn't really say.
  2. From the oe carbs Sent from my DROID RAZR using Tapatalk
  3. What elevation you at? Sent from my DROID RAZR using Tapatalk
  4. Never said it wasn't broke in. Ran it for 2 seasons with the FAST dune/play port on stock carbs. Not saying it needs bla bla. That is what i am saying I'm going to try to start out. Sent from my DROID RAZR using Tapatalk
  5. Installed 45 pilots today. No time to run it. Work sucks. Sent from my DROID RAZR using Tapatalk
  6. Talked to FAST and that's where they said in end up. Sent from my DROID RAZR using Tapatalk
  7. Got her all setup finally. Now for tuning. Running 158/48 CEL mid clip position. Start up with choke at high idle then slows before chokes are shut off. Idles fine with chokes off. Smells a little rich at idle. Checked plugs. They where wet somewhat. Seams to rev nice with slight bog. Air screws are 2 turns out. They seam to have no effect on idle. Thinking of trying a 45 pilot. Bike feels like i gained bottom end power. No WOT run yet for main. Need more room. Lol. What you guys think. Sent from my DROID RAZR using Tapatalk
  8. Bellray gear saver.
  9. Yeah I Have Them. The Alignment Is off.
  10. Cool Thanks guys
  11. Did You Cut The Forward Airbox Mounts Out?
  12. Any 1 Running This Setup. What Did You HaveTo mod To Get It To Work?
  13. Main Looks A Little Fat. Try A 290. Smoke Ring Should Be About The Thi Kness Of A Dime.
  14. what about cutch arm clearance
