Just rebuilt the whole motor got everything from k&t including a 1-5 override. Cant shift override into next gear without the clutch, i hope i don't have to tear this thing down again. Any help would be great! thanks -Mario
My override did this and the centering spring on the shift shaft was worn and so was the essentric screw.
thats what i was getting at lol you explained it a hell of alot better than me.
yea when shifting at 1/4 throttle will roll through all the gears. just when in power it wont shift, unless clutch is used. what fluid should be used for an override?
I run Rotella T6 Full Syn in all of mine,
^ Why I don't like ATF. It is a good fluid for wet clutches and transmission, but you have to keep it cool. The second it gets hot it breaks down fast, which can glaze over your clutches.
