I just picked up this shee from a guy who I think had no idea what he was doing. I went to change the jets and found out that he put mikuni short hex jets on a set of keihin pwk's. I unthreaded the jet and half of the cast carb threads came out with it. So what should I do? Is there anybody that can repair them?
Not sure if it will hold up to gas bit permatex makes a double part epoxy type thread maker..probably better ways though
junk IMO.
no to silicone,  it will more or less prolly clogg the jet and gas will eat it over time.
Plus its not like jetting is set it and forget it.
Other option would be to fill in the hole with JB weld and then drill and retap. I've had success with that method with previous projects of mine. Only thing will be trying to find the appropriate tap for the Mains.
The permatex stuff isnt silicone, it's every bit as hard as jb weld, only reason i would bring it up, we used to on our jet ski and it's pretty amazing stuff.  But like i said, i dont know how it would hold up to 24/7 in fuel/oil.  I would just replace the carb though instead of trying to weld/tap or anything else.
Fuck. Not the answers I was hoping for. I didn't think much could be done but I figured that there was some hope. Sooo anybody have some pwks that they feel like they don't need anymore? Or should I try some other carbs? What do you guys suggest I replace them with. I'm running gas with fmf's, vf3, billet manifold, and k&n pods on stock cylinders.
I didn't think that that tube was able to be removed but I called sudco and thier parts guy said that that is a non serviceable part and not offered seperately by keihin. And that the tubes are not interchangeable between sizes. Pj is not able to get the either... what if I build up some solder where the threads used to be and then run a tap down the hole?
PWK dumps are non removable.
If it was me, I'd call FAST and order new PWKs like $180 a piece or something. Buy new, fuck the headaches of used or Jerry rigged shit.
well damn. So  gas PWK's can't be change over to alky?
