kevincurtis Posted August 5, 2013 Report Posted August 5, 2013 Hey there guys was just wondering if i can get some info on if i should be mixing with race fuel, I have a 421 with 24cc domes at sea level, compression check showed 150 psi each cylinder, I'll be running 91 octane pump fuel, any info would be great ! thanks Quote
Stonytony Posted August 5, 2013 Report Posted August 5, 2013 Idk about 91. I have 4+ timing dune/drag port coolhead 19cc domes 140 psi and have to run 110 otherwise I get detonation because the fuel won't burn properly. Quote
Nightmare Posted August 5, 2013 Report Posted August 5, 2013 Idk about 91. I have 4+ timing dune/drag port coolhead 19cc domes 140 psi and have to run 110 otherwise I get detonation because the fuel won't burn properly. Da fuk you talkin about? Sent from my SGH-T679 using Tapatalk 2 Quote
kevincurtis Posted August 5, 2013 Author Report Posted August 5, 2013 personally i would try to get 93 to be safe. no need for race gas. I'm from New Brunswick so i can only get 91 premium at the pump, I'll just compensate with some octane booster. Thanks for info Quote
oldskool Posted August 5, 2013 Report Posted August 5, 2013 I would keep an eye on for a while. You say 150 psi on comp. Is that kicking comp on cold engine? Quote
n2otoofast4u Posted August 5, 2013 Report Posted August 5, 2013 Idk about 91. I have 4+ timing dune/drag port coolhead 19cc domes 140 psi and have to run 110 otherwise I get detonation because the fuel won't burn properly. I bet its super fast on that 110! Quote
kevincurtis Posted August 6, 2013 Author Report Posted August 6, 2013 I would keep an eye on for a while. You say 150 psi on comp. Is that kicking comp on cold engine? I would keep an eye on for a while. You say 150 psi on comp. Is that kicking comp on cold engine? Yes that's what I got on my comp check with a cold engine Quote
kevincurtis Posted August 6, 2013 Author Report Posted August 6, 2013 Sucks. I have sunoco with 94 that is local. Then about a mile past that, got turbo blue at a pump. That would be nice to have at a pump, not that lucky around here unfortunately, I might go try the local drag track See if they carry 94 Quote
Jereme6655 Posted August 6, 2013 Report Posted August 6, 2013 yea its lucky to be able to have turbo blue just down the street here too......right up until you pull up and look at its $7.50 a gallon.... Quote
mike0chek Posted August 7, 2013 Report Posted August 7, 2013 I'm from New Brunswick so i can only get 91 premium at the pump, I'll just compensate with some octane booster. Thanks for info hey man where in nb are you? i got about the same setup as you and im near fredericton. jeff at fast told me 91 would be safe to run with those domes and 140 comp. Quote
