Turn the motor over and let it all drain out your freshly ventilated piston......
Thats strange... The crank case should always drain when you pull the plug. Id look into tearing the motor all the way down to see what blocked it.
  • Like 1
  The oil in your right crank area is left over premix that was unburnt or spit out the pipe since you had a hole in that piston. Did you notice if was sparkly? piston dust will be hard on the crank bearings.
