Just get the kit, put mine on a couple weeks ago not real bad at all. Drilling and tapping idle screws is hardest part but it's overall pretty simple and so much easier to work on in there.
he might want to just disconnect the TORs without upsetting the tune
How would removing TORS upset the tune??
Well the carbs get angry then upset because you removed it's cap.
  • Like 1
Do the TORS kit. It's pretty simple and gives you a chance to clean out your carbs while you have them off. The hardest part is syncing the carbs and making sure the idle opening is even. Then you can run it up and set your idle. A little tip, every time you remove the carb tops you will need to resync the carbs later.
