If your buying new, just get the 4's. i personally run them and there are several others that run them on this site.. All witch have gave them a good review.
I have a prettty much stock banshee.  fmf pipes, K&N filter/ stock air box , +4 timing.   I would compare the 4's performance similar to what the +4 timing does.  Both are a huge improvement.  especially If your bike is stock.
Oh gezzz....
4 's are the top performer.
Plenty of feedback if you do a search.
on the smaller builds, the boyesen reeds perform just as good as VF.  Some reeds on stock cages actually had a better curve.   once the motor gets more high strung the VF starts to pull away.  I have used Power reeds, pro series reeds, Pyramid cages, chariot cages, VF1,2, and 3's and on the stockish motors I prefer the pro-series reeds on stock cages or chariot cages.   I use chariot cages on everything other then my big bike which has VF3's.
Are v force worth the extra coin compared to boyeson (possibly with ported stock cages)?
IMO,  not unless your have bigger builds in mind.    anything high strung or a builds using bigger carbs, i'd start to look at chariot or VF.
my shee doesn't have much , it  only have crank 4mm, oversized 0.25mm,coolhead ,pro intake,boyesen reeds and stock pipes. i am planning to get the toomey tr6 and the v force 4. would you guys recommend me toomey tr6 and the boyesen reed for the vf 4 ?
i am running stock carb and i want to change them to for a bigger carb cause i ain't feeling the torque like "WAW" what would you guys recommend this with my modificasions? i heard some guys talking about milling a stock 28 mm mikumi to 30 mm would this be great ? or buying a 32mm mikumi?
hee hee
