turbowrenchhead Posted March 23, 2013 Report Posted March 23, 2013 I was wondering if there is such a thing available to replace your stock carb bowls. Its very handy to have the main jet plug access on the bottom of the bowl. Makes tuning much easier. Quote
Zillaguy Posted March 24, 2013 Report Posted March 24, 2013 Hell yeah someone should get on making oversized billet bowls for the stockers! I need a set!!!!! Quote
trickedcarbine Posted March 24, 2013 Report Posted March 24, 2013 Just get one of those chincy deep main jet area extension access bolts. Drill and tap the hole. Or even buy a pair of the access nuts for keihin carbs from Marshall and figure out what size the threads are and order up some bungs to weld to the bowls. Quote
Jereme6655 Posted March 24, 2013 Report Posted March 24, 2013 I don't think there is actually enough room to access from under the carb without loosening the intake boots and twisting the carbs......and at that point its only 4 Phillips screws.... Quote
turbowrenchhead Posted March 25, 2013 Author Report Posted March 25, 2013 Less things to loose in the dirt when you have an access bung. Quote
WINDYCITYJOHN400 Posted March 25, 2013 Report Posted March 25, 2013 Hell yeah someone should get on making oversized billet bowls for the stockers! I need a set!!!!! You don't need oversized bowls for a motor running stock carbs. (especially on gas) The only thing that even remotely would need an oversized bowl would be an alky bike because they flow twice the fuel rate of gas. Quote
n2otoofast4u Posted March 25, 2013 Report Posted March 25, 2013 I have oversized stock carb billet bowl. Quote
trickedcarbine Posted March 25, 2013 Report Posted March 25, 2013 You don't need oversized bowls for a motor running stock carbs. (especially on gas) The only thing that even remotely would need an oversized bowl would be an alky bike because they flow twice the fuel rate of gas. Let's just remember there are some fellas who think its ok to run stockers on stroked cubs.... I guess even then it's not that necassary. Quote
trickedcarbine Posted March 25, 2013 Report Posted March 25, 2013 I have oversized stock carb billet bowl. I swear I've seen the RZ guys with them at track days...... Quote
