I have a few questions. Thinking of building an alki motor. Can i do so on stock cylinders. Is it worth it or just run race fuel.what reeds would I need. This would be my first alki.build. have no clue where to go with it.
List of what I have. 4 mil stock cylindrs drag ported by k&t perf. Pro design cool head 22cc domes custom cut for no spacer. Cases port matched. Ricky stator with timing plate. 34mm mikuni fla t slide carbs
But an OEM stator!
X2
Get carbs setup for alky w/ powerjet, check everything over compression, squish. Make sure you do a few plug chops and see how the alky is burning, and have fun once you go alky you will never go back,
X10 on the OEM stator. You will definitely love alky. Especially since you have a set of stock cyls that are ported by just about the best when it comes to drag racing. Have Kim do your carbs, and it might be worth a conversation with Kim about your domes. If it were me, I'd get a set for alky. It'll only be a few more ponies, but it will show once you are in a situation where you are hot lapping.
Is this bike set up for Drag racing exclusively? I also run stock cylinders on Alky and will never o back.
The purge process is kind of of pain , but it's well worth it. have you considered Lectron carbs?
Keep us posted as you progress.
Troy
^ What Jason said.
I also run 36/38s
Works well for me. My bike dynoed right at 71hp with mild port work & + 4 timing.
I have a new set up coming back this week from a site sponsor.
We're hoping to get somewhere in the 90s with stock cylinders.
Troy
