sandbum80
Everything posted by sandbum80
  1. I've gone through he'll trying to find pistons for my 10 mm that I built. Let me dig up some part numbers I've ran and a lot of research lead me to a we is I piston for a Polaris motor. I'll dig up numbers. They are available just had to do homework. I'll post numbers to piston when I find them today
  2. Rdzs stock cylinders is a big pile of welded up grenades. As proven at mayham
  3. First person that sends me 2100.00 gets a complete motor ported by knt
  4. After being indicisive this motor is bacj up for sale I will sell complete or part out. 7mm knt drag port motor vitos 7mm crank tz bearing 1-5m6 override Brand new clutch 2 passes Brand new lockup stock modified clutch cover powdered chrome billet kicker cases have wack, just went trough motor and blasted and painted cases flat black look amazing. Stock reeds with carbon fiber pedals weisco pistons coolhead (previous owner wedged screw driver inbetween to seperate not pretty but never leaked) Brand new waterpump gaskets troughout. Motor is 100% ready to bolt in and start no bullshit to find on this one. 2650.00 shipped partout topend with pistons and head $1000.00 7mm Crank with tz $400.00 7mm cases w chain wack $225 1-5m6 override $300 Smaller clutch stuff or anyrhing not listed pm me or shoot a text we can figure a price out. 7342606913
  5. Need parts gone $100 shipped
  6. $800 frame brake setup all steering drag tank
  7. the JJ and adraag axle as well as the front spindle mount have been sold need to move this frame feel free to make me an offer I will show up at buyers request
  8. Got a dyna programmable CDI box it comes with the standard switch to switch through curves the switch allows us to be stock through 3 different setup curves from the factory the CDI box is in great condition the sticker on the switch has rubbed off but will give up see that says what's positions are what's curves guaranteed to be working text 7342606913 150 shipped
  9. Changed mind 2800.00 for everything will not take a penny less dont try engine,carbs,pipes shipped
  10. 7mm vitos crank tz bearing 1-4m5m6 override cub cylinders drag ported by knt 68mm weisco pistons lockup stock modified clutch cover pc chrome polished quick change cover stock reeds coolhead (guy before me pryed the tio amd bottom has screw driver marks does not leak tho) Case has wack but went completely trough and sandblasted cleaned and painted high temp flat black. comes with sb/sf knt racers edge out stator side (has shit welds on brackrt where connects two but no visible on bike) Comes with 35mm pumpers with pump and filters will be ready to bolt in and fire motor runs extremely well. I just bought a bigger motor so this one has to go. Text 7342606913 located in reford mi 3250 shipped for it all
  11. thanks guys bike is located in metro detroit, redford mi 48240 the frame is a reverse, the right side lever is for the rear brake, as that can be modified to use a standard style shifter I live the revrse shift and my dune frame will now be a reverse shift after using this frame. Will be going in ebay today
  12. Thanks bro, only reason for selling is motors going to a suspensed chassis
  13. 90" performance prototype chassis bennet motorsports did rear half Setup for reverse shift but just needs pegs to be standard. included: Frame jjna drag axle drag tank shifter front spindle mounts all steering componets I need this gone yesterday.... 1500$ for it all will be on ebay tomm evening if does not sell
  14. Good set of 35 pj alky carbs great condition with pump 215 shipped will be ready to run Sorry for dark pics phone was dead and flash got disabled Text 7342606913
  15. Good luck getting on rdzs baseline with no tuning is 2-300$ and im sure hes tied up anyway
  16. Anyone get video of beezy going for a ride on your turbo Brian?
  17. The reason I asked about stock (new) spring pressure was not because I wanted to use as a base but see the diffrence in pressure from used to new. I have all my baseline recorded, I ended up having to subdtanially lower spring pressure on thursday to get out of hole, ended up a few gear changes and finally starting in 1st ended up picking up around 11mph by end of weekend
