salmon_slayer06 Posted March 11, 2013 Report Posted March 11, 2013 J arm banshee Hot Rods trued and welded +4 mill crank (didn't buy yet) Vertex long rod pistons 64.50mm (In the mail) Stock head shaved to...... I don't know yet I need opinion Shift star mod (done) Shift shaft will be getting roller bearings in the tranny Shift shaft will also be opened up on the end near adjuster Toomey T5's (have already) Keihn Carbs, don't know what size but are better than stock (have already) Boyesen reeds (have already, replacing petals and gaskets) Ken O Connor trail port (will be sending out soon) Port matched Case (" '') Stock air box with cover off K&N filter with outerwear (have already) Fresh clutch rebuild stiffer springs. (done) I would like to advance the timing also but I think I better wait and see how she runs first. I need to replace my head, the right side took a hit when the rod bearing went. I can get stock banshee heads without pitting for around 25 bucks. I'm thinking about getting 2 and having them milled at two different heights. What two would be ideal for 93 pump, and the other for race gas and 93 mix? I do all the building myself except the porting and boring of the cylinders. Any tips and does anybody on here have something similar to this build or know of someone with this setup? Quote
okbeast Posted March 11, 2013 Report Posted March 11, 2013 Looks like a good list. I might recommend having someone rechamber the head completely, or get a coolhead with domes cut to suit. Looks like you're spending a good bit of money already so a bit more to complete the package wouldn't hurt. Quote
BUILDER Posted March 11, 2013 Report Posted March 11, 2013 Sounds like you ate putting good parts in it but I would tell you to call around to the site sponsors on here before you send your cylinders out to be ported. I had the same setup you are building on race gas ported by Redline and I was 74hp on the dyno. I would also say it is well worth the money to go with a cool head instead of cutting a stock one. You will be glad you spent the extra money if you do. Changing domes is much easier and chaper than changing heads and head gaskets. I would advance to timing to plus 4. I do have a used cool head I would sell if you decide you want to go that way. Quote
nmdesertbansheeryder Posted March 11, 2013 Report Posted March 11, 2013 Definately get somebody else to port your motor....any of the site sponsors will take care of you Quote
n2otoofast4u Posted March 11, 2013 Report Posted March 11, 2013 KOC......LMFAO...... This cant be for reals! I call TROLL Quote
locogato11283 Posted March 12, 2013 Report Posted March 12, 2013 J arm banshee Hot Rods trued and welded +4 mill crank (didn't buy yet) Vertex long rod pistons 64.50mm (In the mail) Stock head shaved to...... I don't know yet I need opinion Shift star mod (done) Shift shaft will be getting roller bearings in the tranny Shift shaft will also be opened up on the end near adjuster Toomey T5's (have already) Keihn Carbs, don't know what size but are better than stock (have already) Boyesen reeds (have already, replacing petals and gaskets) Ken O Connor trail port (will be sending out soon) Port matched Case (" '') Stock air box with cover off K&N filter with outerwear (have already) Fresh clutch rebuild stiffer springs. (done) I would like to advance the timing also but I think I better wait and see how she runs first. I need to replace my head, the right side took a hit when the rod bearing went. I can get stock banshee heads without pitting for around 25 bucks. I'm thinking about getting 2 and having them milled at two different heights. What two would be ideal for 93 pump, and the other for race gas and 93 mix? I do all the building myself except the porting and boring of the cylinders. Any tips and does anybody on here have something similar to this build or know of someone with this setup? The things in yellow concern me. Vertex pistons? WTF are those? And please, use someone reputable in the world of Banshees to port your motor. Quote
salmon_slayer06 Posted March 12, 2013 Author Report Posted March 12, 2013 I did not know that Ken had a bad rap on this site. I ran into his videos online of his work and he seems to be a good guy to have working on anyones motor. I didn't have them sent out yet. I've already bought a few things from FAST... which is a site sponsor. Would this be the guy to go through? Quote
okbeast Posted March 12, 2013 Report Posted March 12, 2013 FAST is great. HJR, No Limit Performance, Wildcard...all great builders for what you're looking at. Quote
WINDYCITYJOHN400 Posted March 12, 2013 Report Posted March 12, 2013 I did not know that Ken had a bad rap on this site. I ran into his videos online of his work and he seems to be a good guy to have working on anyones motor. I didn't have them sent out yet. I've already bought a few things from FAST... which is a site sponsor. Would this be the guy to go through? The build you listed would be lucky to hit 60HP. Dome shape is more important that shaved heads or compression. It's a matched system. Do some more research, this site is full of great info. REDLINE RACING FTW!!! Quote
LawDog Posted March 12, 2013 Report Posted March 12, 2013 Jeff at F.A.S.T. is doing my stuff. Id send them thier just my opinion. Quote
salmon_slayer06 Posted March 12, 2013 Author Report Posted March 12, 2013 I'm calling Jeff right now...... Quote
salmon_slayer06 Posted March 12, 2013 Author Report Posted March 12, 2013 I'm going with Dune/Play port, $350 and having both cases port matched $100 along with bore and hone 64.50mm $100 3-4 week turnaround.... Any opinions? Quote
sprinklerman Posted March 12, 2013 Report Posted March 12, 2013 You asked for opinions,so take this for what its worth,but id find something else to buy from FAST for 100.00 before spending 100.00 on case matching. Put it toward some of his domes or something. Quote
troyzstang Posted March 12, 2013 Report Posted March 12, 2013 Gotta agree with Sprinkle on this one . If possible port match & custom domes. Quote
