Methfireroad Posted February 23, 2013 Report Posted February 23, 2013 When I got my bike the previous owner had taken the key switch out and was just use inch the on/off headlight switch. I would like to eliminate the on/off light switch. I'm wondering if I can just replace the on/off with a simple on/off toggle switch. That way I can also locate the switch in a different area.. Any help/suggestions would be great.. Thanks Quote
sheerider11 Posted February 23, 2013 Report Posted February 23, 2013 Just get a tether. It's at least still somewhat of a key. Quote
hoppedupandcutdown Posted February 23, 2013 Report Posted February 23, 2013 Black and black/white wire from switch, connected together- no run. Those two put a switch anywhere. Quote
Starwriter Posted February 23, 2013 Report Posted February 23, 2013 In order for the bike to run, the red/black wire must be connected to the black wire, and the black/white wire must NOT be connected to the black wire. Originally the red/black wire was connected to the key switch and the black/white wire was for the kill switch. Does that clear things up? Switch it any way you want. Quote
Methfireroad Posted February 23, 2013 Author Report Posted February 23, 2013 In order for the bike to run, the red/black wire must be connected to the black wire, and the black/white wire must NOT be connected to the black wire. Originally the red/black wire was connected to the key switch and the black/white wire was for the kill switch. Does that clear things up? Switch it any way you want. I just have the two black/black white wires off the kill switch and I was thinking I would tie the switch into those wires. Quote
tedd1 Posted February 23, 2013 Report Posted February 23, 2013 Yes, just conect those two wires to a simple on/off switch. If it runs now, the red/black wire must be grounded already. Quote
Methfireroad Posted February 23, 2013 Author Report Posted February 23, 2013 Yes, just conect those two wires to a simple on/off switch. If it runs now, the red/black wire must be grounded already. Ok thanks everyone for the info Quote
jbooker82 Posted February 23, 2013 Report Posted February 23, 2013 I would still use a push button kill switch on the bars. I use a honda CR125 kill switch on mine. If you use a togle switch and its not on the bars it might be fun trying to shut it down when your on the back of a run away banshee. 1 Quote
Pastrykiller Posted February 23, 2013 Report Posted February 23, 2013 I use these. Sleek and out of the way until you need it. Quote
Methfireroad Posted February 24, 2013 Author Report Posted February 24, 2013 I use these. Sleek and out of the way until you need it. Who makes that??? Quote
