-Umm, direct drive needs an expensive side cover
-Mattoon sells a good lock up alone but you can use their stock modded covers or expensive DD style
-Gigot is a slingshot that fits under the stock cover with very little nub modification but is pricey
-DriveLine is another slingshot style that fits under the stock cover and has sweet price to boot
What works for you? I run the Driveline unit, love it!
i run a dd. the cover is more bling to spring for, but really, it is bling points. i find people can't stop pointing it out and bragging it up, more than the fingers that warrent it. rule of thumb: up to 80hp, you can possiblyt get away with full had springs. 60hp, need at least 2hd springs. 50+ can benifit a lockup, and still get an easy-pull. 80hp+ best to just get a lock-up. if you don't get that with 421cub, you fail.
