heater Posted July 8, 2012 Report Posted July 8, 2012 So I've got a 03 predator 90 that won't start. It ran fine then the next time I went to start it it wouldn't start and started leading gas out of the carb. I thought needle and seat was bad so I replaced that and cleaned the carb. I put everything back together and it still won't start. Turns over fine. New spark plug, carb rebuilt, good compression. Then it started leaking gas again so I cleaned the carb once again thinking I missed something. Tried starting it and still nothing. Any suggestions. I'm not new to this but I think I am over looking something Thanks Quote
Surfrjag Posted July 8, 2012 Report Posted July 8, 2012 check spark. i have seen stators go bad on these so if you dont have spark you might ohm it. should i post in your other thead too???? Quote
Dicklez Posted July 8, 2012 Report Posted July 8, 2012 Remove the TORS, get a boost bottle, slap on some Pro turners and get a Ricky Stator stator. Buy some electrons and let us know what happens. Quote
themechanic Posted July 9, 2012 Report Posted July 9, 2012 Its always the yamangucci valve on those you can only buy them from the dealer, the same thing happened to my kids bike. Quote
RadarRacing Posted July 9, 2012 Report Posted July 9, 2012 If it is leaking fuel it has a needle or seat prob which it sounds like you have addressed, next would be to set the float level where the float would be lower which will put a little more pressure on the needle. I have built the 50/70/90 cc 2 stroke quads for years and I hate those stock carbs. I pull em off and put a keihin or oko on em. Quote
Rotax Raptor Posted July 9, 2012 Report Posted July 9, 2012 It's most likely the fuel enrichment solinode. Its the black plastic piece thats held on the carb with two screws. If the battery is not fully charged I've seen that effect that fuel enrichment also. Quote
