BLOODRAGE Posted May 30, 2012 Report Posted May 30, 2012 thinking about putting a advance timing plate on the shee,just wondering will i loose top end at 6th gear wot? Quote
BLOODRAGE Posted May 31, 2012 Author Report Posted May 31, 2012 cool.ill try it out after supper thanks for the info Quote
Finch Posted May 31, 2012 Report Posted May 31, 2012 You should like it quite a bit increase. In low end Quote
BLOODRAGE Posted May 31, 2012 Author Report Posted May 31, 2012 i hope so,with the bigbore it should go good with the amount of compression i have. Quote
mike0chek Posted May 31, 2012 Report Posted May 31, 2012 You should like it quite a bit increase. In low end yep, definitely gets into the band quicker Quote
Finch Posted June 1, 2012 Report Posted June 1, 2012 ya thats why its a best bang for your buck mod Quote
twistingixxers Posted June 1, 2012 Report Posted June 1, 2012 ya thats why its a best bang for your buck mod Sure is right about that...Advanced mine ~3 and I was like holy shit..!! What a difference. Quote
EvilBanshee Posted June 1, 2012 Report Posted June 1, 2012 If you run good fuel. Crank it to +7 Quote
maskmanLS6 Posted June 2, 2012 Report Posted June 2, 2012 If you run good fuel. Crank it to +7 How good of fuel are you talking about? Quote
Finch Posted June 2, 2012 Report Posted June 2, 2012 only people i know running that high is on meth but who knows Quote
