dmfisher71 Posted May 10, 2012 Report Share Posted May 10, 2012 ok put a new clutch perch on my shee, and i have no play in the lever and cant adjust it out on the perch... is there an adjuster on the basket i know there is a bolt/screw in it if that makes any adjustment please let me know what i need to do...THANKS Quote Link to comment Share on other sites More sharing options...
Infamous039 Posted May 10, 2012 Report Share Posted May 10, 2012 You need to screw the nut in some. There is an arrow on top of the cases which needs to line up with the clutch arm. Quote Link to comment Share on other sites More sharing options...
maskmanLS6 Posted May 10, 2012 Report Share Posted May 10, 2012 ok put a new clutch perch on my shee, and i have no play in the lever and cant adjust it out on the perch... is there an adjuster on the basket i know there is a bolt/screw in it if that makes any adjustment please let me know what i need to do...THANKS There is a point on the arm that your clutch cable connects to on the bottom end of the cable. That point and the small arrow point on your engine case should be lined up when the clutch begins to disengage. The adjustment on your clutch basket is used to align these to prevent the ball and rod that operates your clutch basket from seizing themselves together. Once that adjustment is set then you can adjust your cable. if you cant get any more adjustment you might just need some new clutch plates. Quote Link to comment Share on other sites More sharing options...
twistingixxers Posted May 10, 2012 Report Share Posted May 10, 2012 ok put a new clutch perch on my shee, and i have no play in the lever and cant adjust it out on the perch... is there an adjuster on the basket i know there is a bolt/screw in it if that makes any adjustment please let me know what i need to do...THANKS I just installed a clutch for my bike...Here is a link that helped me out http://www.toomey.com/html/clutch.htm Quote Link to comment Share on other sites More sharing options...
dmfisher71 Posted May 10, 2012 Author Report Share Posted May 10, 2012 thanks guys very much for the help Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted May 10, 2012 Report Share Posted May 10, 2012 If you had a Clymers repair manual or the download manual, you could do everthing Quote Link to comment Share on other sites More sharing options...
jlsparky7 Posted May 11, 2012 Report Share Posted May 11, 2012 Quote Link to comment Share on other sites More sharing options...
