lms1977 Posted April 3, 2012 Report Posted April 3, 2012 Ok so I run wide open up a hill the have to stop on hill I hear a hissing sound like a air leak from a air hose. it only does it for 2 sec then stops ? I checked the over flow and rad it is not using any water and is not hot at all. if my crank seal on the right side went in therory it could pressurize the engine and come out somewhere I have no oil in the hose from the vent thou I am going to pull all the lines off to see it there clogged etc and I want to pull the side cover off anyway to put a billet basket in it still the stock one anyway I'm wondering if anyone can chime in here and give me some other things to look for. sunday was the first time it ever did it toward the end of day ??? hope I did not destroy it? thanks Mike Quote
360CICJ Posted April 3, 2012 Report Posted April 3, 2012 Check your plugs, make sure they're tight. Quote
lms1977 Posted April 3, 2012 Author Report Posted April 3, 2012 Check your plugs, make sure they're tight. yes they are tight Quote
Zwiser Posted April 3, 2012 Report Posted April 3, 2012 Did you do a leak down test on the engine? Was the engine hot? maybe it was some steam rushing down out the overflow. Quote
slothman Posted April 3, 2012 Report Posted April 3, 2012 if it runs good and you don't hear the noise any more, I wouldn't worry about it Quote
shakar Posted April 3, 2012 Report Posted April 3, 2012 check for snakes under the seat..................lol my filters suck like crazy and makes the hissssss goodluck Quote
slothman Posted April 3, 2012 Report Posted April 3, 2012 my filters suck like crazy and makes the hissssss goodluck good point ! Quote
lms1977 Posted April 3, 2012 Author Report Posted April 3, 2012 It has never made the noise before and the engine is off when I hear the noise . Quote
sheerider11 Posted April 3, 2012 Report Posted April 3, 2012 Do a leak down test. See if you hear it. Quote
lms1977 Posted April 3, 2012 Author Report Posted April 3, 2012 Do a leak down test. See if you hear it. That is what I plan on doing. Quote
BigRed350x Posted April 4, 2012 Report Posted April 4, 2012 Check your coolant level in the radiator. Just because you're coolant bottle doesn't have any fluid in it doesn't mean you can't be low. Toss the stupid coolant bottle in the trash when you are done, they don't do jack shit.... Quote
lms1977 Posted April 4, 2012 Author Report Posted April 4, 2012 Check your coolant level in the radiator. Just because you're coolant bottle doesn't have any fluid in it doesn't mean you can't be low. Toss the stupid coolant bottle in the trash when you are done, they don't do jack shit.... as I stated in 1st post I did check the radiator just to make sure it was full and the engine really was not hot enough to puke coolant Quote
lms1977 Posted April 4, 2012 Author Report Posted April 4, 2012 well I made up a leakdown tester last night and found my airleak looks like a small pc of the base gasket is missing or leaking ... so atleast I caught it before I blew up !!!! so it looks like I will be pulling the top end off to see the damage..!!! thanks for the replies Quote
Jereme6655 Posted April 5, 2012 Report Posted April 5, 2012 Throw up some photos of the carnage....we always like that. Hope you didn't do too much damage to your bike Quote
lms1977 Posted April 5, 2012 Author Report Posted April 5, 2012 Throw up some photos of the carnage....we always like that. Hope you didn't do too much damage to your bike There is no carnage the only thing wrong was the base gasket wa leaking . Quote
