BAMF87 Posted March 10, 2012 Report Posted March 10, 2012 I will be ordering one of the two on Monday and need opinions on which would be better. I'm on a budget and can't spend over 400$ on arms or else I won't be able to finish the build for like three months. Quote
KAMIKAZE Posted March 10, 2012 Report Posted March 10, 2012 i just ordered full flight ones +2+1, wont be able to tell you what there like until the weekend (if they arrive by then) herd alot of bad things about the alba and thats what put me off Quote
Motooutcastxxx Posted March 10, 2012 Report Posted March 10, 2012 If you're talking about these Alba arms; http://www.ebay.com/itm/YAMAHA-BANSHEE-YFZ-350-2-A-ARMS-CHROMOLY-ADJUSTABLE-ALBA-PRO-ELITE-207-AA-B-/190641701398?pt=Motors_ATV_Parts_Accessories&hash=item2c63218216&vxp=mtr I would definitely buy those before the Full Flights, I would take a set of arms that run ball joints before heims any day. I've heard way too many stories of the heim set-ups failing, and have also experienced it myself. With that being said I currently own a set of Full Flights (what can I say the price was right) and in the past have run other brands with heim joints and also have not had any problems other than the annoying squeak of heim joints. Quote
thomas h. Posted March 10, 2012 Report Posted March 10, 2012 After two and one half rides with full flight with chromoly joint the joint get loose and the aluminum spacers get loose. Then I sold the whole chassis for my conversion to yfz450 frame. I would go with alba first Quote
CrazyBRONCOguy Posted March 10, 2012 Report Posted March 10, 2012 (edited) I have both http://bansheehq.com/forums/index.php?showtopic=151890&st=30 pics on page two i believe Just got the Alba's put on. they are beefier for sure. I have the fullflights and I upgraded to their black hiems. I've not had any issues with the fullflights. Mine are still in good shape if you wanted a used set, mine need paint. I also have a set of 2" wheel extension from fullflight to make the rear match the front. But back on topic, the alba's are nicer beefier arm then the fullflights. I like the camber setup too as its easier, not the fullflights where hard just took awhile to get. Also the tie rods that come with that alba are twice as thick as what they are with the fullflights. Edited March 10, 2012 by CrazyBRONCOguy Quote
04zSpittinKlotz Posted March 10, 2012 Report Posted March 10, 2012 I have both http://bansheehq.com/forums/index.php?showtopic=151890&st=30 pics on page two i believe Just got the Alba's put on. they are beefier for sure. I have the fullflights and I upgraded to their black hiems. I've not had any issues with the fullflights. Mine are still in good shape if you wanted a used set, mine need paint. I also have a set of 2" wheel extension from fullflight to make the rear match the front. But back on topic, the alba's are nicer beefier arm then the fullflights. I like the camber setup too as its easier, not the fullflights where hard just took awhile to get. Also the tie rods that come with that alba are twice as thick as what they are with the fullflights. how much you wanting for the full flights? PM me thx man Quote
BAMF87 Posted March 11, 2012 Author Report Posted March 11, 2012 Ill probably order the alba arms. when im done with my build ill have all the pictures in the images section Quote
CrazyBRONCOguy Posted March 13, 2012 Report Posted March 13, 2012 id be interested in seeing your setup with them too. As a heads up the directions dont say it but I had to put the bolt and nut on the shock mount and shock before putting the adapter piece in, of course this is only if you use the stock length shocks. Also I had to turn the flange on the bolts down to go into the tube, not a big deal. Quote
BAMF87 Posted March 13, 2012 Author Report Posted March 13, 2012 Ok thanks for the info I'll post pics in the next few weeks when everything comes back from the powder coater. Quote
BAMF87 Posted March 14, 2012 Author Report Posted March 14, 2012 I just ordered my alba arms. ill post pics when i get them Quote
special06shee Posted March 14, 2012 Report Posted March 14, 2012 I just installed a set of +2+1 full flight arm with elka shocks. I love the way it rides and handles.. Way better then stock thats for sure but i would bet the shocks play a big role in the performance. However the arm themselves are a nice quality especially for the price. And they bolt right up with ease witch is always a plus!! So far i really like the setup.. Id recommend them especially if your on a budget such as myself.. Quote
dimwit Posted March 15, 2012 Report Posted March 15, 2012 I run the fullflights with ASR teflon heim's. The FFR heims are crap and will flog out in no time, doesn't matter what colour they are. keep an eye on 'em. Once you factor the extra expense of the teflon heim's the FFR aren't that cheap. Quote
BAMF87 Posted March 17, 2012 Author Report Posted March 17, 2012 I got my albas in the mail too bad I don't have my frame to mount them, the frame should be back from the powder coater on Monday. Quote
BAMF87 Posted March 24, 2012 Author Report Posted March 24, 2012 Pics of the albas are in the images forum, 97build Quote
Infamous039 Posted April 2, 2012 Report Posted April 2, 2012 I got a chance to test out my Alba Gulf Wing arms this weekend and man do they work great with my Works Dual Rate Front Shocks. I highly recommend them to anyone. Quote
