dimwit
Everything posted by dimwit
they are all chamferred, maybe just bad camera angle about the same size chamfers than on my stock jugs.
being below the port opening, it shouldn't lose any compression eh? by the time the rings are over that the ports will be uncovered anyway
not massive deep or anything, but still there on fresh cyls. after, I'd say should have been bored next size up, this is a trail bike motor that WAS going together and staying together. exactly, they def bit marks not some random scratch yer will def have a talk to him, I was expecting more of a job than this eh.
other cyl
bought a 4 mil kit, other cyl is pretty much the same. paid the going rate for 4 mil ported stockers kit.
would you be happy to run them like that ? don't know if I should be shitty or not
I run the fullflights with ASR teflon heim's. The FFR heims are crap and will flog out in no time, doesn't matter what colour they are. keep an eye on 'em. Once you factor the extra expense of the teflon heim's the FFR aren't that cheap.
true that. coulda had a second bike for what I've spent on freight .
dyno sheet posted here anywhere?
yer, borrinks the go. minkia sucks ass. I got a set of black ones, sent to OZ. 450 + 130 frieght, that's fucken good. can't get a set of fattys here for anywhere close to that. Put 'em on tonight, look sweet, sound sweet. haven't ridden it yet cause waiting for my jets to show up, and fucked my ankle yesterday in a banshee related incident next weekend maybe.
had one on my shee for the last 2 months. It's copped a fair flogging and still straight, and they're right it has a lifetime warranty. can't go wrong for 200bux
borrink's selling black hi-temp and bare steel for 450 + shipping. look in the for sale section "R2's in stock". His chrome pipes are in the platers atm apparently. minkia is doing same for 570 + shipping. There should be a pair of R2's on their way to OZ, cant wait, yippee.
I replaced my key with an inline blade fuse holder. that way you can still make it unstartable, by removing the fuse. hidden real easy, get the proper waterproof ones with the cap. good idea on the light/kill switch, I might piss that off next, and just use my tether as a kill.
all aussie muscle. black XB falcon, 351 cleveland, toploader, 9". 6/71 waiting to go on - but kinda lost interest after buying banshee. blue XWGT, 351 windsor, toploader, 9". is original GT, real collectable over here. $100k car. sold it just before the muscle car boom for $15k. . It's in the will apparentley (sold it to dad). Speedway car is a holden torana. has a stroked 186ci out to 235ci straight 6 with triple webers, supra 5 speed, spooled 9". this races in an unlimited type class against some very healthy small blocks, dry sumped, brodix heads, injected, ect. always a front runner cause it handles the power it's got.
G-Force axle with stock sprocket & brake hub
dimwit replied to 252wheelieking's topic in Banshee Repairs and Mods
if you can move it back and forth, then the splines are worn, simple as that. tightening the locknut up to the speced torque, which you should do, won't fix this . you may not be able to move it by hand once torqued properly, but a 350 twin will move it. If you want to take the slop out of the worn spline you will need to clean it up and use loctite. I would use the loctite product "bearing retainer" it's specifically designed for jobs like this. The problem here was you must not have used loctite on the allen head bolt in the locknut, they, are what clamps/locks the locknut in place. If they were torqued correctly AND loctited your 3piece lock-nut could not have come loose. I think you will find that most USED, if not all USED splined joints like this will have some amount of "slop". My banshee has, and it is a well maintained quad, also running a brand new g-force axle with OEM sprocket and brake hubs. $30 worth of fancy spanner that your probs only gonna use once is a waste of money, it won't fix ya problem. -
yep cool, good advise. I liked my bikes sprung really stiff compared to my mates bikes, they were like" shitman, why dont ya just ride a hardtail". I'd jump on theirs and think "fuck this, this is like a pogo stick". I could land short on road gaps and ride out, they land short and snap frames thats what i'll do then, order a shock with slightly heavier spring and just learn to ride it. and decide whether I need adjustables or not, gotta be tons better than stocko's. I wish my gf new about the wonders of decent suspension,and why I NEEDED it. all I know is there's gunna be a shitstorm coming my way shortly. Shes still spewing about the set of ITP bajas, razr2's, gforce axle. and the +2+1 a-arms haven't arrived yet If she doesn't leave after the shocks, I reckon I'm good to move onto the motor, pipes, cool head, ect with only minor repercusions. haha,haha what a total bastard
thanks matt. that all makes sense. I had a fox float on my mtn bike and wasn't that impressed compared to a coil over so I will steer clear of them. if I can expect the valving to be close but not right, then just another thought. If I saved my pennies until I could afford a shock with adj rebound and comp, set-up to my weight 190lb, would there be enough adjustability in them to get a firm>>soft ride without having to revalve them, hence not having to freight them around the world 3-4 times. dollar wise cheaper shock + shitload of freight = expensive shock + no freight. yes, no, maybe? cheers, thanks for ya time.
i hadn't read the latest in (yfz suspension fix), cause it seemed to turn into a shitfight. but now i've read it i understand 450 shocks no good for me. cheers
okay, I think I've narrowed it down to new shocks no s/h. I'm basically looking at stage 2 elkas, works g series, works steeler series or fox floats. steeler series is alot cheaper but is a fully welded shock that can't be rebuilt, is that right? i've been trying to find out the diff between the g series and steelers. is it worth the extra for g series. i'll keep looking around here it's probs been answered somewhere. thanks for the heads up on yzf450 shocks, i was pretty tempted for a bit $$$.
yep, i hear what you are saying, thats the other option. and this is pretty much what I'm trying to figure out. whether it is worth it to buy s/h top of the line and rebuild, or new stage1/2 shocks, especially considering my riding is fast trail only. no jumps. i know the best shocks you can buy will always be better performers, but compared to mxer's, they are gonna have a easy life, kinda. the problem is I live in aus, so I'm going to buy seconhand racers shocks sight unseen, cross my fingers they aren't junked, and hopefully get the seller to send 'em away to socal. otherwise i'm looking at 150 shipping to oz, 150 shipping back to us for a rebuild, 150 shiping back to oz. all for shocks that could be rooted anyway. i have been looking for s/h elka pep axis ect shocks on the bay, but not to many come up and alot wont ship outside US. yfz450 shocks come up locally often. they are comp and rebound adj and rebuildable. whats your opinions on them? anyone? i think i read they were soft as on shee, but could you get them to work with a rebuild + higher rate spring or give a miss?, the fullflight a-arms i've ordered aren't the ones for the yzf450 shocks but i could mod the shock body if I only got 'em for $80 like the last pair that went off. So do SoCal actually sell shocks or just rebuild what you supply?
thanks, i've been looking at the works shocks. whats the difference between the steelers and the g series? which should i aim for. cheap steering stabilizer, yer, never even thought of that. they'd be a pretty good thing over rocky shit i'd imagine. what's a decent and/or cheap one, are they rebuildable or throw-away, how much $$. everyone seems to steer clear of triple rate springs cause a banshee is front heavy, that right?
Yer thanks man, I got off pretty light injury wise, only really ground off one of my love handles with the rear tyre as it was running over me . got it straightened pretty quick, went riding last weekend with some two wheeled bike mates. one mate tryed an overtaking manouver on a firebreak that just wasn't there . ended up landing his front wheel, 2010 yzf450, you know the fuel injected rocketship ones, on one of my back tyres, i look over as in "what the fuck was that" to see his bike doing cartwheels and him doing a "superman doing yoga @60mph" impression. man he is sore, (and a sook). so now looking for another riding buddy for the time being, preferably one not made from marshmallow . as I tell my injured mate. for a dimwit I am a bastard.
