thomas h. Posted December 2, 2012 Author Report Posted December 2, 2012 I had rough road fabrication do it. They did my engine and custom intake too. I have a new seat pic ill load soon. Leaving for glamis tomorrow. Quote
thomas h. Posted December 6, 2012 Author Report Posted December 6, 2012 Ok glamis trip fail. Overheating. Around the block is fine. up the dunes not so much. I installed the head air bubble tube to a adaptor in the upper radiator hose. I though that the cooling system might have loads of air making it hot. Btw the sticker the the heat reading sucks going to get a gauge. So I ( @ glamis ) replaced the upper hose and put the air bubble line on the over flow nipple and removed the rubber seal on the cap. I hoped the system would fine a happy level after it pushed out the expanded fluid but it didn't. The couple bowls I did ride made me happy I did the project and I'm going to correct the cooling issues with a gp radiator 75 $ eBay ( any input on this would be great ) also a newer style shroud that put more air in to radiator, temp gauge, hi pressure cap and weld in or adapt to sensor hole the head bubble line in. Might try water wetter, inline cooling device. Also have a billet impeller all ready. What do you think Quote
thomas h. Posted December 6, 2012 Author Report Posted December 6, 2012 you do know that a stock yfz and stock banshee both have the same front wheel travel of 9.1" so i have going to go out on a limb here and say that a LT shee will have more shock travel than a stock yfz in the front. Looks like I miss typed stock shee is ? 13" don't know right now and stock Yfz 450 is 14.25. Agree that they are close but currently my Yfzshee has 19.50 quad rate elka and +3 leagers arms. The point of this conversion is to get really good suspenison to handle a super fast motor. Is the LT banshee shock about 14.25 -15.25 ? Do you want to talk about my overheating issues ? I agree with you don't convert your frame if LT banshee is better than stock Yfz. But my ported 4 mill is really strong and I really like that I moved my motor more forward to help get the power to the sand and the stock rear link is a big plus. I think it is like having a +2 +4 banshee extended rear swinger. Quote
thomas h. Posted December 11, 2012 Author Report Posted December 11, 2012 Roll designs arms take 17" shocks for banshee. I agree the first thing I noticed was my lean was more comfy and my Yfz 450 desert tank was really use full in holding my position. The 450 fame is just skinnier than banshee. I really like that my motor is more forward too Quote
thomas h. Posted December 11, 2012 Author Report Posted December 11, 2012 I gotta post so new pics of oversized radiator. This project puts a huge grin on my face Quote
thomas h. Posted December 18, 2012 Author Report Posted December 18, 2012 Got my seat fixed. Didn't have the heart to tell the guy that the first one he made was crap. http://www.flickr.com/x/t/0095009/photos/91231464@N07/8285299616/ Photobucket fails me right now Quote
thomas h. Posted December 18, 2012 Author Report Posted December 18, 2012 That reminds me you guys never mentioned that it (old seat)was really was ugly. Quote
thomas h. Posted December 18, 2012 Author Report Posted December 18, 2012 New radiator http://m.flickr.com/#/photos/91231464@N07/8285371652/ Quote
matt1 Posted January 27, 2013 Report Posted January 27, 2013 Did you (thomas h) ever get anybody to cut off the resi and make it remote? If You did please post who did it or pm me. I have not come up with a good airbox around the resi. I built an airbox and it ended up being to restrictive on the resi side. When you went to an oversized tank did you have any clearance issues with the pingle and spark plugs? I ended up relocating the pingle to the the middle of the tank to get enough clearance. Are you still having overheating issues? Maybe you have a bad radiator, I ride in the florida heat and have yet to have mine try to boil. I run the YFZ radiator and still have the crappy plastic impeller Quote
theneil Posted January 27, 2013 Report Posted January 27, 2013 really nice bike man, this is my next project so i have an excuse to build a 10 mil twister for it Quote
thomas h. Posted January 30, 2013 Author Report Posted January 30, 2013 Did you (thomas h) ever get anybody to cut off the resi and make it remote? If You did please post who did it or pm me. I have not come up with a good airbox around the resi. I built an airbox and it ended up being to restrictive on the resi side. When you went to an oversized tank did you have any clearance issues with the pingle and spark plugs? I ended up relocating the pingle to the the middle of the tank to get enough clearance. Are you still having overheating issues? Maybe you have a bad radiator, I ride in the florida heat and have yet to have mine try to boil. I run the YFZ radiator and still have the crappy plastic impeller Well yes and no. I have pics but what I did was cut off the top shock mount turned it counter clock wise then turn the the resi to the horizontal position and reweld done. Send me your email for pics Quote
thomas h. Posted January 30, 2013 Author Report Posted January 30, 2013 My ims tank pet cock clears well Also my overheating 4 mill is going to get a bigger radiator engine ice 2.0 rad cap and cut out the middle of the front bumper Quote
thomas h. Posted January 30, 2013 Author Report Posted January 30, 2013 Also hooking up the stock fan and trail tech gauge and maybe more shrouds to get the air in and a battery try for the fan and hids Quote
thomas h. Posted February 23, 2013 Author Report Posted February 23, 2013 The eBay yfz450 gpx radiator Pros cheap, bigger tanks, thicker core and aluminum plugs where the sensors go. Con mount tabs are 7/16 high and the Eletric fan mounts are 3/8 off too. Build note: have oversized radiator installed befor custom pipes are made. Currently mounting battery and hooking up fan. Quote
thomas h. Posted February 23, 2013 Author Report Posted February 23, 2013 Also cutting out the center of my front bumper. Quote
