01 banshee partout Aftermarket and stock
  • Replies 72
  • Created
  • Last Reply
Top Posters In This Topic
Lsr +4 Swingarm, pc silvervein some of the powdercoat is chipped off. Its solid no cracks or repairs. Comes with longer chain. $225
Full Toomey T5 exhaust system (pipes and silencers) Good overall shape normal chrome wear up near cylinders. 225
Chrome steering stem stock height. $60
Complete bottom end, Good stock crank and tranny, also Comes with flywheel and good stator with both covers. No leaks. Cases are good they have a very small little chip missing from the chain hitting. $300
Cylinders 64.5mm Good bore/crosshatch ( only .5mm over stock Means lots of bores left in them) $225
Complete clutch , basket plates everything $50
Stock radiator $10
Thumb Throttle assembly (tors plug cut off) $10
Intake boots with crossover tube $10
Chrome spindles with front wheel hubs and rotors Good bearings. $50
Rear wheel hubs $40
Brake hub and rotor rear, rotor shows some wear but still useable $10
Axle carrier Good bearings $50
Orange tank cover and grill plastic $30
Black maier front fenders factory race cuts, and black radiator/grill plastic $40
Rear plastic (painted black) $20
Front plastic cut (painted black) $20
Red front plastic with tank cover and grill/radiator plastic $40
Blue tank cover $10 (cpl stress marks)
Stock seat needs recovered $10\
Kickstart lever and knuckle assembly $20
HEadlight/ run switch works good small peice of Hi/Lo headlight switch broke off still enough there to use $10
Misc hardware/parts lot Shifter, Pipe hangers, chain adjusters, steering stem clamp/bushing, headlight mounts, engine mounts... all for $20
Edited by f4istunna
spindles/hubs just sold yesterday sorry
carrier sold also
heres whats left
+4 Swingarm, pc silvervein some of the powdercoat is chipped off. Its solid no cracks or repairs. Comes with longer chain. $150
Complete bottom end, Good stock crank and tranny, also Comes with flywheel and good stator with both covers. No leaks. Cases are good they have a very small little chip missing from the chain hitting, outer crank bearings will need replaced. $200
Complete oemclutch , basket plates everything very nice shape $50
Rear wheel hubs $40
Misc hardware/parts lot Pipe hangers, chain adjusters, steering stem clamp/bushing, headlight mounts, engine mounts... all for $20
never had headlights sorry
Cylinders are sold now aswelll.
Ill take offers on the rest looking to clear some room in the garage
Rear wheel hubs $40
