SFB172
Everything posted by SFB172
Sold! Thanks for the interest.
Stellar +2+1 J-Arms, powder coated black. Come with hubs and extended brake lines. Looking for 250 shipped, not interested in any trades since I'm out of the Banshee game for now. I did a part out almost a year ago and never managed to sell them, I was packing up to move and pulled them back out.
Bump, One trans, 15 tooth sprocket, kick starter, clutch and flywheel SOLD
Bump, Cases SOLD
All prices include shipping, please add paypal fees. Vito's Big Bore Cylinders, makes a 421 with 4mm crank. Fresh Nicasil, low hours. -600 V-force 3 reeds, well used -140 Pro design cool head, 18 and 20cc big bore domes, head has some wear on outside and could use fresh o-rings -130 Good set of engine cases, no chain damage -140 Stock flywheel -Make Offer Ignition Coil, stock winding spliced into ricky-stator pickup and on adjustable RS timing plate, No plugs on the end I was using weather pack plugs with it -60 Used 14 tooth and new 15t sprockets -5 each if thrown in with another purchase. TM Designworks case saver - 30 Brand new in the package pivot works front wheel bearings -20 Stock kick starter -Make offer Stock clutch basket with good clutch pack - Make offer Clutch push-rod pancake bearing- Make offer Two complete stock transmissions, I see from searching they have been a tough sell, if you're interested in one let me know. Probably going to be somewhere in the 100 range on those. Bundling is encouraged especially on some of the smaller stuff. I can be emailed at e.taylor217@gmail.com, if you have any questions or want other pictures just let me know. E-mail is the fastest way to contact me, I get it right to my phone. Thanks, Ethan
Sorry not looking to separate at this time. G-Force Axle- SOLD
Bump, CPI'S SOLD
Swingarm, Carrier, clamps, hangers and T-5s SOLD
PM's Replied
I am parting out my 87' Banshee, I decided it was time to sell it off. All prices include shipping, some prices negotiable. Paypal is preferred for payment. PM or E-mail me at e.taylor217@gmail.com with any questions. Rough set of CPI BB in-frames-250 Right hand attach flange cracked inside and out, had it welded once. Left Collector Dented/Chafed in two areas Mid-pipes and silencers are in moderate condition Toomey T-5's in ok condition. Repacked silencers have about 6hrs ride time on them-250 A few blemishes, dents. Toomey Spark Arrestors-115 Ims 4-gallon desert tank with dual pingel. No need to cut front plastic with this one-250 Nology Coil and Plug wires, comes with mounting bracket I made to mount it in the stock location-120 +6 round carrier swingarm, comes with chain, chain guides, and brake line- 260 Roundhouse Carrier-125 Stellar +2 +1 J-arms built for YFZ shocks, 10hrs ride time, I can include the hubs if wanted or i can break down, comes with extended dual brake lines-400 G-Force Extended rear axle-140 HLS Elite Series YFZ Shocks-350 PWK 35mm Airstrikers, comes with full compliment of jets-200 Picture doesn't show them but caps, slides and throttle cable are included. Exhaust Hangers and Cascade clamps-Make offer
PM sent on stator.
That is some impressive carnage
Sounds like my trip to Glamis last week, disaster sums it up. Still had fun and all luckily we brought a spare bike so i could still get around but i was disappointed that my bike was down. Good luck with the repair
PM sent on oversize tank.
Man i have wanting to drive one of the new F-150s either the 5.0 or the Ecoboost, from what i hear on the F-150 forum the new engine line is way better than the Triton line ever dreamed of being. I would agree that the new dodges have a good aggressive look to em its a leap back to the early-mid ninety's style that I always liked, they finally dumped the dopey massive headlights. I think one of the best looking trucks right now is the GMC 2500s I have seen a few lifted ones around and they give me a bit of a stiffy haha
That's why there's $10,000 in rebates on Dodges, cant give em away. I have an 08 F-150 and love it, haven't had a single problem with it. But seriously that does seem like a lot of problems for any truck even a Dodge, sounds like you got a lemon, but its no good for lemonade. Go trade it in for a Ford and be done with it haha
Did you end up getting the silencers figured out? I just repacked my silencers and if you have any questions let me know, the Toomey site is kind of vague as to how they go together. The baffles aren't welded in like on some pipes they just slip in on each end, takes a little patience but eventually everything lines up and you can put the caps back on. Toomey also has the repack kits and baffles on their website, not to pricey either, that's where i ended up getting my parts.
This is my first attempt at lending advise so i hope i don't botch it to bad, im sure if i get anything wrong someone will certainly call me out on it If you suspect you have some loose ball joints or tie rod ends one way to check it would be to jack the front wheels off the ground and push/lift on the tire and watch for any slop/play in the ball joints. Being an 87 its highly possible that some or all have taken a beating and have a little play. Wider arms are going to give you more stability and a wider stance, if you do a lot of blazing in the woods your going to want to consider whether or not an additional 2 or 4 inches of width in the front is going to be a hindrance. Having a set of wider arms built also allows you more choices in what shocks you want to run, from what i have gathered even going to a stock YFZ 450 shock which are longer than banshee shocks are a huge upgrade over stock. Im actually building an 87 right now and Tim at Stellar is building a set of extended J-arms for me, were both in Tucson so i got to go to his shop and look around when i placed my order, his fabrication is on point and i cant wait to get my arms, so i would say if your thinking about getting a set made hes the guy to talk to, great guy to deal with. Hope this helps and im sure some other people will chime in as well.
PM's sent
Looking for some pipe clamps for T-5's, also looking for hangers, and a set of k&n pod filters for 35mm pwk's Thanks
What year bike? Im looking for front brake lever with brake light leads.
PM sent on reeds.
Looking for a set of T-5 silencers if anyones got an extra pair they would be willing to part with. I have a set of FMF fattie Pipes and Powercore silencers that i would be willing to trade. The pipes are in good shape but the pipes going into the silencers are bent, previous owner told me someone had heated them up and bent them to use on a go cart or some foolish thing. I know they arent worth much in their current condition but maybe someone could do something with them. Cash or trade let me know Thanks
keihen35 mm pwks andbillet intakes 2 piece
SFB172 replied to tz racin's topic in For Sale - Parts & Accessories
Maybe my second PM didnt go through, sent you an email. Thanks -
Are these sold? Sent a PM yesterday.
