951banshee350
951banshee350's Achievements
  1. How much for the Vforce.!? The valves in good shape?
  2. Costco how much for the clutch cable..what brand is it!?
  3. HEY Costco! Do you have SS braided clutch or throttle cable.!?
  4. You got a timing plate..?
  5. I second that! ! WheelManslim.. thanks to all for your thoughts and comments ..I am gonna look into leak testing after new pistons and compression check the good cylinder.
  6. Just in case : another left out Mod. Runing a Dual Pingel valve..fuel is flowing fine.
  7. Fuel was fine.. I still have a chance to check my compression on one side. I wonder if it was too high. I will be checking that tomorow.
  8. Wouldn't my pistons have seized B4 they blow a hole of I was running Lean!?
  9. Pilot 30 Main 300.. and im running K&N pods.
  10. Help!! Here's my Mods..Fresh top end build 66mm Wiseco pistons,T5's,CoolHead 22cc domes,stock timing,stock Crank,BR8 plugs,stock Carbs,stock reeds,91 octane ..32:1 castor 927 mix. Broke in the build B4 heading to GLAMIS it ran fine no issues.. then in GLAMIS while dunning it goes WOT! Shuts off ..came home to a hole on my left piston & a hole starting to form on my right piston..what gives!!
  11. Clutch insert how much shipped to 92880?
  12. Vforce. Reeds are these still available? Are they VF2 OR VF3's.? How much$$
  13. How Much for the clutch insert?
